Turn Off Touchpad on Windows 10
461,805
6
64
Posted in TechnologyLaptops
Introduction: Turn Off Touchpad on Windows 10
When I upgraded my OS to Windows 10 on my Asus laptop, I lost the ability to turn off my touchpad using fn+f9. I looked online for ways to help solve this issue with no success. Hopefully this will help anyone who is having similar problems.
Step 1: Open the Task Manager
Open your task manager, ctrl+alt+del, or by searching for it.
Step 2: Select Startup Options
Select the startup tab along the top.
Step 3: Disable ETD Control Center
If you don't immediately see ETD Control Center, you can sort the programs by their status.
Disable it by either right clicking or pressing the button at the bottom right-hand corner.
3 People Made This Project!
  • Spotless Contest
    Spotless Contest
  • Microcontroller Contest
  • Space Challenge
    Space Challenge
2 Questions
ETD does not come up for me... Any suggestions?
At the bottom right click the windows button and click settings. Once in settings, click devices, then touchpad. after that, click additional settings and it should bring up an app called mouse properties. Once inside of mouse properties, click Device settings and click on the device with touchpad or trackpad in its name. once selected, click disable and apply. There you go. your track pad is disabled. Just repeat the same process, but click enable if you want to use it again.
I followed your instructions but there is no ETD anywhere in the Task Manager.
I really dislike Microsoft telling me that I have to use the pad and not my mouse. They have been telling me what to do for a long time, i.e., no CD/DVD software, etc. Gates seems to be a very benevolent man, but MS has lost that.
Sincerely, Pat
64 Comments
I had posted this when I first upgraded to Windows 10. What brand model are you using. I can turn mine on and off from the settings with my current build. Try searching for touchpad in the searchbar.
Finally solved this. Nothing else worked for me but the directions i've listed below.
-Go to Settings
-Control panel
-Uninstall/Change program
-ASUS Smart Gesture
-Repair.
-Restart Computer
THEN
-Start (bottom left)
-Control Panel (type it in the search box)
-ASUS Smart Gesture
-Mouse Detection
-Disable touchpad when mouse is plugged in.
If you don't have ASUS Smart Gesture you can google it and download it.
Thanks BillD116 - Your suggestion of installing ASUS Smart Gesture worked for me!
i registered to thank you kind sir.
Thanks a million, BillD116. This worked for me too! The problem was driving me nuts.
Thank you for this solution. I have never been more frustrated trying to work than with this problem. I can say that the above solution worked albeit....I already had the ASUS Smart Gesture cr*p installed but didn't know anything about it configuring it. All I needed to do was find the app and disable it....easy, peasy. I don't know why PC makers design/install so many obtuse features. My laptop is a tool....much like the hammer I have....and it doesn't have to be rebooted.
Disabling and removing the device/drivers was a useless effort.
No repair option under ASUS Smart Gesture, only delete.
BillD116, Thank you. Nothing else worked. I didn't have the ETD Control center anywhere. but you my friend saved me.
Worked!!! Thank you very much. This is going to make ALL the difference
Thank you kind sir.
Thank you SO much. Have spent hours trawling for a solution and this worked like magic.
Thanks for the tip. The old method gave me nice black screen....
Thank you BillD116. I've tried several sites and a bunch of ideas and none worked till your suggestion. Very Helpful, I was able to finally disable my touchpad.
GailS63, it's great to hear that this has been helpful experience.
Somehow my ASUS Smart Gesture app has been deleted/uninstalled for unknown reasons, I don't know how did it got deleted/uninstalled, this gave me confusions because I'm currently using ASUS ROG GL552VX which should have all ASUS related programs installed in it, I had this problem for 3 days, I kept on searching for answers through different sources, and then I saw this, thank you very much, this really helped.
Trust me, I know your frustration MohM28. Happy to help.
I just registered here to thank you. Your comment solved my problem! You are the best!
Thanks DiogoL18. I've had this problem for a while too. I thought I'd share the solution.
Finally a solution that fit my computer! Thank you BillD116 for this!
