Turn Off Light From Bed
8,403
33
27
Posted
Introduction: Turn Off Light From Bed
Well my mom likes to wake me up for school in the morning my turning on my light, and I got tired of being blinded first thing in the morning and having to walk across the room just to turn off the light, so I decided to make a quick way of turning off the light from my bed. This is a fairly easy instructable (i think), i also thought it was quite fun to do. Note: this only works with the flip-style light switch.
Step 1: Materials
Parts:
old light switch cover
dc motor
project box (i used an altoids tin)
2 momentary push button switches
lots of wire
2 AAA battery packs (I used 1 AA and 1 AAA)
heatshrink tubing
hot glue sticks
a screw
Tools:
drill (not shown)
soldering iron
wire cutters/ wire strippers (not shown)
hot glue gun
Step 2: The Case
I drilled a hole in the side for the wires going to the motor to go out, then I drilled 2 holes in the top for the wires to the buttons.
Step 3: Build the Circuit
Follow the schematic below to build the circuit. But: DO NOT ATTATCH TO MOTOR YET! just twist the 2 ends together for now. Make sure to thread the wires out of the holes for the buttons before soldering. I hot glued the 2 battery packs to the bottom of the case and hot glued the 2 buttons on top to hold them in place.
Step 4: The Motor
For this step, I held the motor against the light switch to figure out where to position it and marked with a pencil. now take off the faceplate for the lightswitch. I drilled a hole for the screw to come up to help hold the motor on the plate, then I hot glued the motor onto the faceplate. you may have to loosen or tighten the screw to get the motor to turn off the light efficiently.
Step 5: Final Touches
now solder a wire to each of the ones you twisted in step 3. (there should only be 2, both have a positive and negative twisted together) then thread the 2 wires out of the hole in the side of the case (put a knot on the inside to prevent the cable from pulling out). now solder the other ends of the wires to the points on the motor. now just screw the faceplate back on the wall. finally figure out which button turns on the light and which one turns off the light (I made a label). and test it out to make sure it works.
Step 6: All Done!
below is a video of me using my switch. please comment and rate. I hope you enjoyed this Instructable. thanks for viewing :)
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
26 Comments
You can also induce a short circuit to switch off all lights - you just need a plug socket...
youtu.be/A4ci7fRyh1Y
Thanks! I'm glad you like it!
where'd you get the motor?
out of an old rc car
100x better than mine mine is just mechaical
Sounds like you could maybe use the wireless guts of the car to make this wireless too.
i was going to try and do that but the circuit was fryed somehow and about the only thing i could use was the motors, but if i can find another rc car and some other parts im going to make a second version of this
ohh this is a sick idea though
thanks :)  and you could probably go to an hobby shop and get a servo instead of that motor btw.
