3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn the Pope into Palpatine
Step 5The animation.
The animation.
Make sure the first frame in the animations window is selected, and press the 'duplicate selected frame' button, then drag the duplicated frame to the end.
You should now see three little photos, in the order of pope, palpatine, pope.
Now to make the morphing!
Select the first frame (should be the pope) and click the tween button. For the people who don't know what this is, it is on the animation window, and looks like 4 dots, each with different opacitys.
A box should pop-up, and the only setting you will need to change is the frames to add.
Make it about 50, the higher the number, the more frames and the slower it goes.
Now go to the second last frame which should be the one of Palpatine just before the Pope.
Select it and do the same.
You should now have quite a few frames there.
Click the play button and it should be morphing Pope Benedict XVI into Emporer Palpatine!
You can play around with it to get it right, just keep undoing until you find the best one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:codykage
