This instructable will show you how to connect a Magtek magnetic card reader to an AVR or Arduino/clone and read data from the first track of card. Buckle your seats; magnetic card readers have a high bit rate!
Remove these ads by
Signing UpStep 1The Equipment List
- Magnetic card reader (Mine is a Magetk 90mm dual-head reader. $5.00)
- AVR, Arduino, or clone (ATmega328p ~ $4.30 from Mouser.com
- solderless breadboard
- some wire
- maybe a header if you like that sorta thing.
- something to read your serial port. I use AVR Terminal from BattleDroids.net
Build_it_Bob
Cheers!
-gian
I have an Arduino... but normally you have a .pde extension in the .zip i dont see any. Can you please help me, how can I use your code into Arduino.
Thank you!
Another question did you use a Magtek MiniWedge Stripe with RS232 or usb or keyboard?
Re: your other question. My magcard uses a serial protocol that I describe in this instructable. It's pretty standard but doesn't use USB. I had the Arduiono redirect output to a windows terminal via RS232.
Good luck!
Cheers!
-gian
http://jbsaundersco.com/
Good luck!
telling another, to some dufus writing it down and misplacing it and it falls into the wrong hands.
It would be cool to make a door lock for a house with this =)
the maglocks are they are called in the locksmith/access control business
come in a number of holding force pound ratings. 300, 600, 1200, 1500 & 3000
# ratings. And they are NOT positive latching, meaning that they have to have CONSTANT power to hold. If power fails, you need sufficient battery backup amp hour capacity. hope that info helps.
control system. certainly doable! :)
Stumbled across this.
A good starting point?
