3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Turn your Dead PC into an Aquarium"
Step 2Side Panel Cut
Side Panel Cut
The first thing you need to do is determine exactly where your tank is going to be placed. Once you find this out mark the center of your tank. Measure the distance from the bottom of the PC case to the middle of the tank. Then measure the distance from the back of the PC case to the middle of the tank. Transfer that measurement to the side panel to determine where the center of the tank will be. Determine the circumference of the tank. Use a compass to draw your circle on the cover.
Once you have your circle drawn its time to cut the circle out. Using a drill press or drill with a 3/8 in drill bit, drill a pilot hole within the circle as close to the line as possible. With the cover securely clamped down to a sturdy surface cut out your circle. The hole doesn't have to be perfect as the trim will cover the cut. Once your circle is cut use some 120 grit sand paper to knock the burr off on the edges.
I made some trim to make it look like a port hole on a boat  but you could use anything like some car door trim or leave it as is.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
26
Author:pbecker83
