3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn your EAGLE schematic into a PCB
In a previous Instructable, I provided an intro to schematic entry using CadSoft's EAGLE editor.
In this instructable, we'll make a printed circuit board from that schematic
I guess I should say that we'll make a PCB DESIGN; making the physical board is a different task, and there are a lot of tutorials on the net (and even some instructables) on making the board after you have the design.
Cadsoft EAGLE generic information:
Cadsoft EAGLE is available from http://www.cadsoftusa.com/
Cadsoft is a German company that is a veritable mecca of software distribution enlightenment. In addition to the reasonably-priced professional PCB design packages ($1200), they have freeware, lite, non-profit, and other intermediate licenses. Their software runs under windows, linux, and MacOSX. It's slightly quirky, with a steep (but not too high) learning curve on the front end, but from most reports it is not any more so than other professional CAD packages. They have online support forums that are active from both the company and other users, the package is under current development and gets better with each release. A number of PCB fabricators will accept their CAD files directly. It's good stuff.
Use it. Propagate it. Buy it when you "go pro."
See also:
Schematic Entry
Creating Library parts
Design rule modification
Send CAD Files to manufacturers
Step 1Starting from the schematic...
So this is the schematic we have from the Schematic Instructable. Up in the file menu, there's a "Switch to board" selection. If we do that from a bare schematic, it will offer to create the board from the schematic for us (say "yes"), and then leave us sitting in the Board Editor.
126 comments
1-40 of 126next »
Mar 27, 2012. 10:12 AMstuffstuffa says:
How can I mirror the whole board?
Mar 12, 2012. 12:16 AMthypnotist says:
Your a Ledgend.
This is exactly what I needed to know from start to finish.
Thanks heaps.....
David
Jul 25, 2011. 9:07 PMsallen14 says:
Nice tutorial!
I've been designing boards and schems using Eagle for a while now, but where I am coming unstuck is finding someone who can make a PCB from the board file that Eagle produces.
My main board maker can't use the Eagle files, he only wants files in Protel (Protrax etc) format.
My alternative boardmaker also can't use the Eagle files and is asking for Gerbers.
So far I have not been able to find any program that can convert Eagle files to either of these formats.
I did contact one boardmaker who said they could produce a board for me using the Eagle files, but they wanted something like $150 to make one board!!
Any suggestions?
Sep 19, 2011. 4:31 AMWichers says:
You might try silvercircuits.com. They are much cheaper and can produce boards directly from the eagle files.
Sep 5, 2011. 12:16 PMaessam1 says:
Amazing,very helpful tutorial
and i have a small addition here
to export the PCB for toner transfer
view only (pads,vias,bottom layer)
then print from file menu
and mark (mirror,black,solid)
thanks
Jul 15, 2011. 11:11 AMptorelli says:
Hello,
Great tutorial, much faster than the web-based videos.
What are your recommendations on production houses? I googled PCB fabrication and found a dozen or so shops that provide their own cam files. Rates range from $50 to $150 for a dozen or more 2"x2" 2 layer boards. Before I plunk down that much for a mistake, wondering if you have any favorite places?
thx,
p
Aug 17, 2010. 9:43 PMabraxas2 says:
Now that the autoroute has destroyed my hours of work, how do I undo it ? Undo doesn't work !!!
May 10, 2011. 2:22 PMcomputurwizard says:
You can undo the autorouter. Click the ripup icon, then on the top toolbar click the little traffic light icon. A window will pop up asking if you are sure. Hit Yes.
Apr 29, 2011. 6:36 PMeriol says:
using this instructable for creating a guitar pedal with friends.
thank you for sharing
Feb 9, 2011. 5:27 PMjonnyphenomenon says:
Great instructable man. I just finished reading the "how to draw a schematic" one and loved it. you helped me figure out what i was doing wrong. :)
I sure would like to be able to download that hobby.dru file, but the site keeps telling me I need to be logged in. (I am logged in, or else I wouldnt be able to post this) Anyway, guess I will have to follow your instructable and just make my own :)
Apr 17, 2011. 12:24 AMbmlbytes says:
Try the hobby.dru file on this page.
http://www.instructables.com/id/Make-hobbyist-PCBs-with-professional-CAD-tools-by-/
Apr 17, 2011. 10:14 AMjonnyphenomenon says:
Thanks! I dont remember how I did it, but somehow I was eventually able to get it. the only problem I had after using your hobby.dru file was that I coudlnt change the shape of my pads. so some pads on transistors violated the rules. I ended up exporting my drawings into coreldraw format and trimmming them there.
Mar 20, 2011. 9:19 PMhightekrednek2396 says:
if only i could put ten stars well done now in 30 minutes i know how to make boards in eagle thanks
Jul 22, 2010. 2:14 PMalr206 says:
How do you get it to incorporate contacts that are connected to gnd? Everytime I try, it excludes those areas (I am using your design rules file). Thanks -- your instructables have been VERY helpful!
Aug 19, 2010. 9:50 PMabraxas2 says:
Every time I try to rename a signal path or pad, in board view, it says "Cannot Back Annotate ...Change in Schematic View" So after many attempts I finally manage to change one of these items names to "Base" , in schematic view, since it connects to a transistor base. It prompts me with an invite to connect Base and Gnd, I respond "no". The adjacent signal path which I do want renamed gnd, keeps on resetting to the name Base and won't let me change it to gnd...no matter how many times I try. Worse yet, when I do the gnd plane, both the Base and Gnd signals get tied to the plane. It's driving me nuts.
Aug 20, 2010. 1:28 AMabraxas2 says:
The only thing I can see is that I have some very faint phantom lines connecting the Base and GND traces. These are lines I believe left over from a Rip Up repair. I'm guessing the program still thinks these items are connected.
Jul 23, 2010. 7:11 AMalr206 says:
I didn't realize that what I actually had was thermals, so the pads should appear a little bit different under a closer view than in the pictures above. Thanks again!
Aug 19, 2010. 7:52 PMabraxas2 says:
I can't thank you enough for this excellent tutorial. I thought I'd never get the hang of it and it's not a very intuitive program. Do consider turning these tuts into a book. Now hopefully one last question : after drawing the ground plane with the ratsnest command I got a nice big plane but also a bunch of tiny little islands that serve no purpose but to make the board look dumb. I tried erasing these islands with the rip up but it just ripped up the closest vital wire instead. Is there away to zap these tiny little island ground planes ? Thanks MUCHO !!
Aug 20, 2010. 1:25 AMabraxas2 says:
It mysteriously fixed itself. Thanks.
Jul 15, 2010. 1:49 AMNaved Ahmad says:
Hello Every body: This is N-A-G from Afghanistan, I need help If any one has the basic, intermediat or advanced notes about making remote control, motors, tank treads, PCB [in pdf format or any other format] please send them to any one of my accounts i will be thankful of that person. or if any body has any link or some ones email, gmail, hotmail, skype, yahoo that knows about the thinks i wrote above please send them. i will be thankful of that person again. thanks alot buddies. Contact: [0093 (0) 794 50 63 43] - [0093 (0) 706 71 98 93] E-Mail [nghafori@af.mercycorps.org] Gmail: [navedahmadghafori@gmail.com] Yahoo: [navedahmadghafori@yahoo.com] Skype: [naved.ahmad.ghafori]
Jul 5, 2010. 2:41 AMnicolo86 says:
Really useful, but i have a question. Is it possible to make two different PCB connect with each other. if yes how. thanks
Jun 10, 2010. 5:55 PMtomtortoise says:
yo when i did this step the two non-polar capacitors disappeared from the whole thing? i have know idea what happened to them and i still barely know how to use the program.
Apr 7, 2010. 7:00 AMamando96 says:
 swett, helped me a lot
*faves*
Mar 29, 2010. 11:58 PMabraxas2 says:
Sorry but I'm missing something here. I've got a nice picture of components and lines between them. I need artwork, that is to say a black and white transferable image for final etching. I'm not seeing that under export. When I get the export image it's just a copy of the board layout with all these component images included. I just want the conductive lines and pads ???.
Mar 29, 2010. 11:59 PMabraxas2 says:
I'm using 5.6.0
Mar 9, 2010. 5:32 PMpuffyfluff says:
Just to let you guys know, if you want cheap factory-made PCBs, try BatchPCB.  It's a service run by Sparkfun for PCB manufacture.  The prices are $2.50 per square inch on 2-layer boards or $8.00 per square inch for 4-layer boards and a $10 setup fee (all USD).  There's no minimum quantity.  It takes a few weeks depending on when you place the order, but it's still pretty slick.
Jan 23, 2010. 10:57 PMsimplicio says:
What I do to get onboard power connections is to drop "test pads" onto the schematic from the testpad library (e.g. TPSQ/TPSQPAD1-13). That way you get thermals around the pads which makes them easier to solder.
Dec 4, 2009. 7:51 AMDimitrios says:
Really nice instructable. I am actually looking for someone who can make a pcb layout. Who can help me? It's a small schematic with 13 components (resistor/diodes/transistors) Like 2" x 2". I am not knowledgeable enough to use a cad program. Anyone who can help me, pls message me with your email so I can email the schematic.
Apr 7, 2009. 12:32 PMjoeuhlik says:
Why does Eagle want to draw the polygon as line segments rather than as a rectangle as you show?
Nov 13, 2009. 4:47 PMdiyuser says:
How would you tell Eagle not to draw polygons/power planes when auto routing. Just plain wiring.
Aug 31, 2009. 12:13 AMkeithongrq says:
i've done every thing here and the end result look good but when i save the file and reopen it, the polygon becomes a rectangle made of dotted lines. some help please thanks
1-40 of 126next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
