3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn your EAGLE schematic into a PCB
Step 12Route remaining tracks manually
The autorouter did a pretty nice job here. There's only one trace left.
There are a couple of ways we could route this signal manually, including some snakey routes between transistor pins that the autorouter didn't use because of the design rules we specified. This is a relatively high current trace, and I decided that I won't manually violate the design rules either. Instead, I'll use a jumper wire on the component side, which I can model in EAGLE as a top-side trace.
Select the ROUTE tool and click on an endpoint of an unrouted (yellow) airwire, and you can position a trace pretty much anywhere you want, selecting width, layer, and type of bend from the menu bar as you go along. This is shown in the succession of pictures in this step.
5 comments
Jul 17, 2008. 8:21 PMLeroy says:
Step 12 clued me in on how to make a jumper for an unroutable trace! THANK YOU! I take it if I need to use a jumper on the component side of the board, I should just click the VIA button on board-layout to make a via, right?
Jul 4, 2007. 11:00 PMjosheeg says:
It mentions use the middle button again what does the middle button do?
Jun 16, 2007. 2:12 AMhashir says:
How can i convert yellow wires into blue wires?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
