3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn your EAGLE schematic into a PCB
Step 13Add power plane polygons
"Power planes" are large areas of copper that carry an actual signal, usually power and ground. On multi-layer boards, it's common to have entire layers mostly dedicated to such a power plane. Even on a single layer board there are some advantages to doing something similar:
1) Use less etchant
2) carries heavier current, just in case
3) makes it easier to attach test leads
4) acts as a sort of "static barrier" to fingers
In EAGLE. such large signal areas are drawn with the "polygon" command. There is an icon on the toolbar for drawing polygons, but it will create polygons associated with a new signal, and I find that when creating a polygon for an existing signal, it's easier to type the text form of the command in the text command area. To create a polygon attached to a signal named 'gnd', type "poly gnd" By giving it a signal name in the command, the polygon will automatcailly be connected to that signal. (If you draw a polygon with the icon, you can connect it to a signal later by using the "name" command to rename the polygon. (however, after this, you can't rename the polygone again without renaming the signal as well.))
20 comments
Jul 22, 2010. 2:14 PMalr206 says:
How do you get it to incorporate contacts that are connected to gnd? Everytime I try, it excludes those areas (I am using your design rules file). Thanks -- your instructables have been VERY helpful!
Aug 19, 2010. 9:50 PMabraxas2 says:
Every time I try to rename a signal path or pad, in board view, it says "Cannot Back Annotate ...Change in Schematic View" So after many attempts I finally manage to change one of these items names to "Base" , in schematic view, since it connects to a transistor base. It prompts me with an invite to connect Base and Gnd, I respond "no". The adjacent signal path which I do want renamed gnd, keeps on resetting to the name Base and won't let me change it to gnd...no matter how many times I try. Worse yet, when I do the gnd plane, both the Base and Gnd signals get tied to the plane. It's driving me nuts.
Aug 20, 2010. 1:28 AMabraxas2 says:
The only thing I can see is that I have some very faint phantom lines connecting the Base and GND traces. These are lines I believe left over from a Rip Up repair. I'm guessing the program still thinks these items are connected.
Jul 23, 2010. 7:11 AMalr206 says:
I didn't realize that what I actually had was thermals, so the pads should appear a little bit different under a closer view than in the pictures above. Thanks again!
Aug 19, 2010. 7:52 PMabraxas2 says:
I can't thank you enough for this excellent tutorial. I thought I'd never get the hang of it and it's not a very intuitive program. Do consider turning these tuts into a book. Now hopefully one last question : after drawing the ground plane with the ratsnest command I got a nice big plane but also a bunch of tiny little islands that serve no purpose but to make the board look dumb. I tried erasing these islands with the rip up but it just ripped up the closest vital wire instead. Is there away to zap these tiny little island ground planes ? Thanks MUCHO !!
Aug 20, 2010. 1:25 AMabraxas2 says:
It mysteriously fixed itself. Thanks.
Apr 7, 2009. 12:32 PMjoeuhlik says:
Why does Eagle want to draw the polygon as line segments rather than as a rectangle as you show?
Nov 13, 2009. 4:47 PMdiyuser says:
How would you tell Eagle not to draw polygons/power planes when auto routing. Just plain wiring.
Aug 31, 2009. 12:13 AMkeithongrq says:
i've done every thing here and the end result look good but when i save the file and reopen it, the polygon becomes a rectangle made of dotted lines. some help please thanks
Mar 5, 2009. 2:41 PMjimmy dean says:
When I try and draw a polygon, it's never filled in. When I finish the polygon it just makes a rectangle made of dotted lines.
Mar 8, 2009. 6:40 PMjimmy dean says:
Oh, i didn't do the ratsnest, thank you.
Jul 4, 2007. 11:12 PMjosheeg says:
This part is super cool! I am making a board with power gnd and analog ground so I need 3 different polys and this helps reduce noise. Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
157
Author:westfw
Middle aged geek username also works at yahoo.com, mac.com, comcast.net, wharton-10.arpa
