3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Turn your Junk Hard Disk into a tool grinder
Greetings,
Turn your junk hard disk into a tool grinder!
note: this not my original idea, this was already featured here in Instructables before.
I just want to submit my own version. I also found out not all Hard disk can be converted to a grinder, some won't spin when you rip out the read/write head, while others, motor are too weak and stop spinning when load is applied.
So far, i discovered that a Seagate Barracuda 3.5 inch desktop hard disk has a strong motor and spins at 7200 rpm. I used the 20GB and 40GB model..
Just follow my pictorial instructable here if you plan to make your own.
Step 1
Tools needed:
1, torx screw drivers set
2. Phillips screw driver
3. sharp x-acto knife
4. pliers if needed
5. clear goggles - for eye protection
Parts needed:
1. Old Seagate  Barracuda hard disk drive
2. Different Grit water proof sand paper (floor sander paper recommended)
3. Power supply - 5volts/12 volts, the one used for external drive.
15 comments
Sep 2, 2010. 11:53 AMagis68 says:
Very clever indeed!!!!!!!5/5 for the idea and the job done
Oct 8, 2010. 6:50 AMmhkabir says:
But the original idea was not yours, please mention the instructable and the author in the acknowledgements
Kabir
Oct 10, 2010. 10:44 PM2 stroke says:
its him who posted the instructable i guess he was not trying to be rude eh
Oct 8, 2010. 11:06 PMmhkabir says:
Well I am the author >> check my profile
Aug 6, 2010. 4:17 PMa_traceur says:
Great idea! Although I might add something important. I've found that with the types of drives I tested it on (luckily I had multiples) if you remove the read/write assembly the motor will stop working. What I did to fix this is just snip off the ends of this assembly and leave the rest in place.
Jul 22, 2010. 1:12 PMJural says:
Great idea. If you used velcro on the platter you could then use the velcro style sand paper.
Jul 22, 2010. 11:48 AMKaelessin says:
Hey this is pretty cool . . .how much weight can these take though . . .i'd expect that a little too much pressure would throw it outta whack no?
Jul 22, 2010. 11:15 AMSirisC says:
Where did you find that power supply?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:profpat
