Turn Your Fence Into a Gate With 17$
Introduction: Turn Your Fence Into a Gate With 17$
If you need to move large items(Go Kart, Picnic table, or a vehicle)in and out of your back yard here is a cheap and very easy way, with 17$(if you don't have to buy any tools).
Step 1: Plan (what Do You Want Bring Through the Gate)
How long do you need the fence to be? You can not take out the main post they are cemented into the ground. If you do your fence will have no support. I needed a minimum of 88"(inches), my main posts were 95" apart...I'm in luck!
Step 2: Tools and Materials
All of these items can be found @Lowes or Home Depot.
- 4" heavy barrel bolts Qty 2
- 4" removable pin board hinge Qty 2 !ALWAYS MEASURE FOR YOUR PROJECT!
- hack saw(for wood)
- drill with phillips bit
- extension cord
- hammer
- tape measure
- gloves
- extra wood screws(the hinge and barrel bolt come with screws)
- something to mark with, such as a pencil
- shovel and/or rake
- ladder(if the fence is too high)
Step 3: Remove Panels and Mark for Cuts
Using your hammer or pry bar, pry off and remove the panels where you would like to cut. This is not a science, there is no right or wrong just make sure you pull the correct panels off to get the correct length. !EVERY FENCE IS DIFFERENT SO USE COMMON SENSE WHEN DOING THIS PROJECT!
Next, measure and mark at what point you want the gate hinges to swing and the barrel bolt to latch.
Step 4: Cutting the Fence
Where you marked the line to cut, using the hack saw, cut down that line at a 50 to 60 degree angle as shown, so the gate doesn't bind when it's opened or closed.
Use the rake and/or shovel to remove the grass and dirt under the fence to allow the gate to freely swing open and close.
Step 5: Installing the Fence With Hardwear
Remember the Panels we removed, we will use them as a spacer between the bottom of the fence and the ground. this is done to elevate the fence to the proper height so the hardware lines up. !Take your time on this part! You might have to add and remove the panels (spacers) to achieve the correct height.
To mount the hardware, stabilize the cut portion of the fence back into its original space. As you see in the picture, the swinging portion of the fence is a bit higher to give the fence swing clearance. Using the drill and supplied screws, mount the hinges and barrel bolts.
Step 6: Reinstalling the Panels
Use the additional screws to install the panels back onto the fence in the original spots. Mount the panels ONLY to one side(either onto the stationary part or swinging part) not both or the fence won't open. Swing the gate open to see where to mount it.
Step 7: Take a Step Back and Check Out Your New Fence Gate
You shouldn't even be able to tell that you did anything to the fence.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    Check building codes in your area.
    My fence has an 10 ft opening with two 5 ft gates. Each side has 6x6 posts with concrete footings. The other posts are 4x4, but only the corners needed to be in concrete. If I did this to a section in the center of one of the runs I could risk pulling the post out of plumb.
    when i saw the picture i thought u were just gonna say get a big truck and drive though it
    Indeed, I thought: get a big truck, drive through the fence and topple it! Should you get sturdier hinges? Will it sag?
    you could pre-emptively install a reinforcing rod from the top hinge to the opposite bottom corner and just tighten it if you notice any sag... Or, since it's not really a regularly used "gate", then it shouldn't sag if it's well supported by your latches on the other side...
    me too ikill lol, but then i thought hmmm whats the 17$ for lol
    Thanks for the comments! macdadyabc, for a strat up welder I would suggest a high 120V(volt) or low 240V, such as MillerMatic 140 or 180. Lincon and Hobart are always good too. Write me if you need further help with them.
    Good Idea, it's simple to make and it somehow hides the gate itself. Nice car btw ;)
    very simple, yet effective. nice instructable. do you have any suggestions on a start-out welder. the most i need to weld is 3/8. thanks
