***Disclaimer*** The following is for informational purposes only, I take no responsibility for what you do with this knowledge.
Remove these ads by
Signing UpStep 1What You Need
I have less pictures of this project because i built it out of a active subwoofer and so it is a bit different. but its very easy and watching the final clip you will understand everything.
IMPORTANT: Before you search for the materials read through the whole tutorial else you will have problems to fit the parts together!
What you need is:
1) a old speaker from 40W upwards
2) a Hi-Fi with "line in" or a amplifier.
3) a 100 to 200g weight, if possible flat and round. (i made mine melting some lead into a steel cup.)
4) some wires
5) screws
6) a office chair to use
Tools:
1) sharp cutter,
2) soldering iron
3) screwdriver
4) glue suitable for the material of weight you use
I used this active subwoofer. Active means that it has a amplifier inside and does not need an additional one. The disadvantage of mine is that it uses a signal coming from the player to switch on and off so I had to bridge the circuit.
36
comments
Add Comment
bowmaster
says:
bowmaster
says:
bowmaster
says:
bowmaster
says:
bowmaster
says:
matseng
says:
LasVegas
says:
noahw
says:
noahw
says:
Add Comment
![C:\Users\Sharky\Desktop\IMG_0042[1].jpg](http://img.instructables.com/files/deriv/FEH/VVY0/F6S8Z0WK/FEHVVY0F6S8Z0WK.SQUARE.jpg)
![C:\Users\Sharky\Desktop\IMG_0060[1].jpg](http://img.instructables.com/files/deriv/FH2/NZZ2/F6S8Z0WE/FH2NZZ2F6S8Z0WE.SQUARE.jpg)
