Step 2Prepare the Speaker
1) (most common) you will see the membrane and at the center of it a tiny rounded membrane.
2) you will see the membrane and a smaller hi frequency speaker at the center of it (this one is not suited for our project)
3) (best for this project but most difficult to find, can be found inside woofers) you will see the membrane and a round flat 5cm disc at the center.
In both suitable cases you need to remove the membrane, letting the lower (usually brown) membrane intact. Be careful not to cut the upper membrane where the wires are attached. If you make it correct you are going to let only a 2 cm large peace of the upper membrane removing the rest. This step is important, else your chair is going to play music.. :D
Now to the second part of preparing the speaker: this is different for the case 1 and case 3 speakers (see above). for the case 1 speaker you need to cut away the little rounded membrane at the center. After removing it you will see a hole, it is a cylinder on which the coil is mounted. You can use this hole to mount your weight. It is important that you do NOT deform the cylinder else the coil touches the magnet and it could start to burn. the best way to do this is to put a little peace of garden tubing inside the tube and then screw a big screw inside using it as a weight.
For case 3 speakers everything is easier. if you can find one of these it is better for several reasons:
MUCH more powerful
easier to build
usually a low frequency speaker
you can find these inside subwoofers.
in this case you need to glue a weight centered on the disc (use the correct glue!). thats it.. :)
5
comments
Add Comment
Add Comment
![C:\Users\Sharky\Desktop\DSCF0016[1].jpg](http://img.instructables.com/files/deriv/FTU/POSD/F6S8Z0WJ/FTUPOSDF6S8Z0WJ.SQUARE.jpg)
![C:\Users\Sharky\Desktop\IMG_0046[1].jpg](http://img.instructables.com/files/deriv/FM5/2ZSF/F6S8Z0WG/FM52ZSFF6S8Z0WG.SQUARE.jpg)
![C:\Users\Sharky\Desktop\IMG_0067[1].jpg](http://img.instructables.com/files/deriv/F0Y/Q8RE/F6S8Z0WI/F0YQ8REF6S8Z0WI.SQUARE.jpg)
