Turtle Pendant From a Nickel
11,050
158
19
Posted
Introduction: Turtle Pendant From a Nickel
Again inspired by mrballeng here on Instructables, this is a pendant made from a nickel!
The nickel was hammered flat, then filed into the correct outline. I then used paperclips to create the indented lines, and sanded/polished the piece smooth.  The curve was created by hammering a dome-headed bolt onto the piece while it was sitting over an indent in a block of wood.  Epoxy was used to secure the jump ring.
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    19 Comments
    Make a instructable. I am trying to make one right now
    this is highly illegal.
    It's only illegal to alter/deface currency that you intend to keep using as currency.
    @Kryptonite:
    Giving some alternating texture and polished areas, on the shell, might also give it a nice little something different. There's endless possibilities. Very nice piece of work there Gnome!
    Whoa! Very cool. My girlfriend loves turtles, I'll have to try and replicate this!
    Have you considered a little detailing with something like black modeling clay (such as mrballeng used in the art palette and cufflinks instructables) in the lines of the shell?
    If I understand his instructables properly, it seems that the clay itself has no inherent adhesive qualities. He carefully engineered those pieces to have lips that would hold the hardened clay shapes in.
    Also, I think I prefer a clean metallic look. Could be something to explore, though! If I found a paint that went well on metal it could be interesting.
    Very nice pendant! I'm actually planning on making one for my sister's upcoming birthday. I was just wondering the steps I should take.
    Is it hammer out, round, file to shape, and then indented? Or is it some other order?
    Thanks!
    1. Hammer a nickel until the features are no longer visible. Try to hammer evenly. Balance thinness with the size you want your turtle to be, it's up to you.
    2. Draw the outline of the turtle on with marker or something, and use wet metal files to shape the silhouette. File the sharp corners down a little.
    3. Bend some paper clips to the shapes you want for the lines. Hold them in place with masking tape and give them three or four medium hits with a hammer. They tend to flatten a bit, so it's best not to reuse them.
    4. Get a piece of 2x4 or something and hit it with the ball end of a ball peen hammer, making a round dent. Place the piece over this dent and find a round-headed screw. Hammer the head of the screw down all over the piece until it becomes domed.
    5. Sand a lot. You can try hot gluing something to the back so you can handle it, then tape some 100 grit paper down on a very flat surface. Let the sandpaper do most of the work, and switch directions occasionally. Work up through 400, 1000 and 2000 grit.
    6. Get some polishing compound and rub it in, buffing it dry afterwards.
    7. If desired, epoxy a small jump ring to it for easy attachment.
