Tutorial: Laser Cutting From Solidworks
Published
Introduction: Tutorial: Laser Cutting From Solidworks
This tutorial outlines the process of getting parts from Solidworks to cut on Universal laser cutters.
Step 1: Load Your Part in Solidworks
Step 2: Make a Drawing From the Part
The document size does not matter. To make things easier on yourself, be sure to de-select the "Display Sheet Format" option.
Step 3: Add the Desired View, and Set Scale to 1:1
This step is very critical. If the scale is not set correctly, your part will not cut at the right size.
Step 4: Save the File As a .AI, and Open in Adobe Illustrator
Step 5: Copy the Part to a New Document
Set the document size to the cut area of the laser cutter. Check to make sure the color mode is RGB.
Step 6: Release Compound Path, and Join Paths
Solidworks applies a compound path to the entire part. Release it, then join continuous sections of your part.
Step 7: Compensate for the Laser Kerf Using Offset Path
Select all outer paths, and apply the desired offset. For most Universal lasers I've used on material 1/8" or less, I set a kerf of 0.003". Set the miter limit to something large- I typically use 50.
Select the inner paths, and apply a negative offset. In this case, -0.003".
Step 8: Delete Original Paths
Zoom in, and delete the original paths
Step 9: Applied Desired Stroke Color
Select your part, and create a new swatch under stroke.
For most Universal laser cutters, R255 G0 B0 indicates a vector cut. Use whatever your cutter requires.
Step 10: Cut!
Now, you can launch the print driver to send the cut to the laser cutter.
Step 11:
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    6 Comments
    I like to export as DXF, select the face I want or a view, and then import that DXF straight into AI. I think this generally simplifies the workflow and removes any potential risk of scaling errors.
    DXF also means that solidworks will not export as a compound path!
    Thanks for this great article.
    In case you're having trouble making an even offset, or reducing the stroke width of your offset, make sure "Align New Objects to Pixel Grid", under 'Transformations' is unchecked before you create the offset
    10/10 amazing instructable. Thank you tons
    really nice instructions. Very clear and easy to understand
    This was very useful.Thank you!
