Spot Welder for Lithium-ion 18650 Battery Tutorial
4,928
33
9
Published
Introduction: Spot Welder for Lithium-ion 18650 Battery Tutorial
Easy to build DIY spot welder for under 60$.
Works great und safes a lot of time.
High temperature destroys lithium batteries, so soldering is no option.
I want to build a 700Wh battery pack for my electric homemade boat and E-bike using 60 panasonic ncr18650b lithium batteries.
Step 1: Watch the Video! Check Schematics for the List of Material
Thats all you need:
1 x resistor 1k
1 x resistor 10k
1 x foot switch
1 x Hifi Cap min. 1F
8 x MOSFET IRF1404
1m copper cable 2.5mm²
2m copper cable 35mm²
Copper rails
Total costs: about 60$
Step 2: Attach the MOSFETs and the Eyelets to the Copper Rails
Sand the copper rails for better
contact.
The eyelets are very easy to bend (watch the video)
Step 3: Wooden Base Plate and Copper Clamps
Attach the Hifi Cap to the wooden base plate.
Make the copper clamps for the 35mm² cable and the cap.
Use wodden distance plates to attach the copper rails with the FETs and eyelets.
Step 4: Solder GATE and SOURCE Pins
Solder eyelets to the SOUCE pins of the FETs.
Connect all GATE pins.
Dont´t foreget 10k resistor between GATE and SOURCE
and 1k resistor after the foot switch.
Step 5: Welding Cables and Connector
Connect one 35mm² welding cables to the plus pole oft he cap
and the second to the DRAIN copper rail.
I also installed a connector for the battery and the foot switch.
Step 6: Welding Tips
Use for the welding tips the 2.5mm² copper cable.
Stick the 2.5mm² copper cable into the 35mm² cable as shown in the video.
Now you are ready to do your first welding tests.
To load the Cap use a power supply or a 12V battery with a 60W lamp in series.
Benefit of the power supply: you can vary the amount of energy in the cap.
Have fun!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    9 Comments
    What would be a good way to protect the MOSFETs? After a couple test welds, all of them fried :(
    thats sad to hear! were the mosfets hot to the touch or did they just blow directly?
    I've built one! I assembled the parts around the cap with 3D printed parts. I also built an Arduino powered relay switch just to make sure that the pedal presses are consistently the same 100ms. Thank you for the tips!
    Hi, it would be nice if you showed us what components you used. Thanks
    The cap is a "2F" (more like .5F) from Boss Audio. Got it from Amazon for like $33. I used 10x IRF1404 just because I had 10. Got them from Aliexpress for around $2 for 10pcs. Two 18650 cells in series used for the switching of the mosfets. Copper rails from Aliexpress. 2AWG Battery charging cables from Amazon. Arduino Nano with a 5V relay to turn the mosfets on/off at a consistent length of time. I'm still dialing it in.
    Do you have to watch how long the step switch is pressed down - or does it just drain all the current from the cap so there's only one pulse and that's it? What would happen if you held the pedal down?
    Looks good! Just for reference if you would like to break down the steps into written instructions and add some progress/step photos so that others can replicate your projects then it will receive more attention from the community and be possible to be featured on the site. https://www.instructables.com/id/How-to-Create-a-Fe...
