Introduction: Tutorial on Making Christmas Hoop Earrings With Seed Beads and Glass Beads
Christmas is right around the corner, so today we’d like to share you a pair of Christmas hoop earrings, you can make them for your Christmas holiday.
Step 1: Tool and Materials Needed to Make These Christmas Hoop Earrings:
2mm Green Seed Beads
2mm Red Seed Beads
4mm Red Glass Beads
Golden Earring Hooks
0.2mm Fishing Wire
Scissor
Step 2: Make the Inner Hoop of the Christmas Hoop Earrings
1st, cut about 80cm fishing wire and alternatively slide 14 red seed beads and 14 green seed beads to the wire;
2nd, cross the wire through the first seed bead to make a bead hoop;
3rd, add 2 green seed beads, 1 red seed bead, and another 2 green seed beads onto the wire, and cross the wire through the nearby green seed bead to make a tiny flower pattern like picture shows;
4th, repeat previous step to make more flower patterns in the same way.
Step 3: Make the Outer Hoop of the Christmas Hoop Earrings
1st, add 2 green seed beads, 1 red glass bead, and another 2 green seed beads onto the wire and thread the wire through the nearby flower pattern like picture shows;
2nd, keep adding green seed beads and red glass beads in the same way to finish the outer hoop;
3rd, once finished, add an earring hook to the hoop pattern to finish the beaded hoop earring.
Step 4: Here Is the Final Look of These Seed Bead Hoop Earrings:
Wow! These earrings are so Christmas! Just with some normal beads and basic beading skills, you can easily make these Christmas earrings with 30 minutes! Don’t hesitate, just give it a try and merry Christmas!
