Introduction: Tutorials on How to Make Cheap Easy Crafts- a Beaded Leaf Pendant Necklace
Maybe most of us are busy everyday and we don't have enough time to make statement jewelry. Therefore making some cheap easy crafts is a good choice for you. In this tutorial, I will show how to make a beaded leaf pendant necklace. It's very easy to make and just take you less than 10 minutes. Have a try!
Step 1: Materials and Tools Needed in the Beaded Leaf Pendant Necklace:
6mm White Pearl Beads
8mm White Pearl Beads
Brass Jump Rings
Brass Chain
Copper Jewelry Wire
A Set of Three Pliers
Step 2: Begin to Make a Beaded Leaf Pendant
1st, cut off 18cm 1.5mm aluminum wire, and bend two small loop on the both sides;
2nd, wrap a 0.5mm copper wire on the aluminum, then string some 6mm white pearl beads, 8mm white pearl beads and eye cat bead on the cooper wire, make sure you should twist the cooper wire after stringing a bead.
Step 3: Finish Stringing Beads and Twisting Copper Wires As the Picture Shows
Step 4: Add Jump Rings and Brass Chain to the Beaded Leaf
Step 5: The Final Look of the Beaded Leaf Pendant Necklace:
Such an easy craft and I can't help to make another one for my best friend. What's more, leaf also stands for friendship and I hope we will be friends forever like this left pendant necklace. Do you like the beaded leaf pendant necklace? Try to make one for you and your best friend, hope true friendship forever!
