Tux the Linux Penguin Costume
 by halfbad333
Featured
Step 12: Getting in and Out
Depending on your size, you may require a larger or smaller access point. Make sure you can get in and out before you put the Velcro on. I sewed the bottom half of the lower curvy part of the belly onto the main body of the costume, and the curvy part at the top, also sewing a couple inches down from the top curvy part. The rest of the area I used as my access point. Ideally I would have used a zipper for this, but I had no idea how to attach a zipper so I used Velcro instead. CAUTION, do not try to sew Velcro with a sticky side. It will gum up your needle and not sew at all. Either use the Velcro without a sticky substance on the other side, or use hot glue to hold the Velcro to the fabric.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
