3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tweet-A-Temp
Step 4What is a Thermistor?
A thermistor is a resistor that changes resistance with the temperature. Using the techniques from the Voltage Divider to determine the Resistance, we can tell what temperature it is.
The problem is that I have some cheap thermistor in a casing from a 10 year old product. How was I suppose to create a function to go from a resistance to a temperature? Well, I have a Thermometer that it plugs into!
So I measured a lot. I copied the temperature down and then measured the resistance of the Thermistor. I placed it in the fridge, then I place it in warm water. Later I would grab room temperatures since I had time.
I supposed I could have read the Wikipedia plage can tried to guess the a and b factors, but I assumed I was using a non-linear, possible failing component that no longer matched it manufacturing specifications. Oh and I am lazy.
So I dumped all the values into Excel, and then graphed it.
I was originally worried that I had to remember the deep dark math of something like "least squared fit" when I discovered that Excell will do this for me!
Clearly I am missing gaps on the graph, but I got lots of good data around hot tub temperatures (100-105F).
While checking the room temperature ranges I noticed something, that almost makes my work worthless. The "Precise Temp" thermometer reported a 3-7 degree error between "indoor" and "outdoor" when the Thermistor was inches away! Now this might be because I mixed and matched thermistor between units, but I am betting it has more to due with quality of a 10 year old, $10 item&
Regardless of the "accuracy" of the temperature, I needed precision and multiple tests of the same range showed very close results over days. In the long run I will likely attach the thermistor to a pipe leading into the hot tub, so I will need an offset anyway.
So by getting Excel to display the equation, I then put it into the code, and so far it is "close."
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Z0t
