3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tweet-A-Temp
Step 5Transmitter Circuit
Transmitter Circuit
The Transmitter circuit is simple. I chose a 100 kOhm resistor for R2 since it looked like it would fit the range from the graph, and I had a spare one from desoldering various things with the Minions. I connect this in series with the Thermistor via a connector. Then I added a battery pack. I Ran 3 V to VREF and the Top of the Voltage divider and to the Xbee +3V input. I put the GND (Battery Negative) to the GND input, and to the bottom of the divider. I then connected AD0 (Volts in) to the middle of the Voltage Divider Circuit.
AD0 will read a relative voltage from VREF to V(1). So as the battery declines, the relative voltage should decline the same. Eventually I will power the unit with a local power source.
The finished unit worked fine, we connect everything with alligator clips, which made it fragile. After I got the female 3/32" connection, I place the transmitter in a random plastic tub we had (an ex-hummus container). This should protect it from weather. Since I bought "panel mount" connectors, it was as simple as drilling a hole in the plastic to add the connector to the outside with a fairly water tight connection.
Once we had that it was time to test.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Z0t
