Tweet-a-Pot: Twitter Enabled Coffee Pot
248,447
307
99
Posted in TechnologyArduino
Introduction: Tweet-a-Pot: Twitter Enabled Coffee Pot
About: I'm a full stack web developer focusing on security and privacy.
Like the idea of making coffee on the fly? from your bed? While you're on the bus coming home? Then the Tweet-a-pot is for you!
Tweet-a-pot is the next in fancy twitter enabled devices. This coffee pot enables its owner to make a pot of coffee from anywhere they have cell phone reception, using twitter and an arduino board.
The tweet-a-pot is the easy implementation for remote device control! with a bit of code and some hardware, you can have your very own twitter enabled coffee pot.
Take a look at this quick video, Special thanks to Sam:
Step 1: Supplies
To make your very own tweet-a-pot you will need the following
1 Power Switch Tail, this is basically a relay that is used to interface with the AC voltage
1 Arduino Board (any will do)
1 Computer running the arduino IDE and Python
1 Drip Coffee Pot
Step 2: Setting Up Your Computer
First you need to set up your receiving computer.
To interface between the arduino and twitter, we are going to use python. There is a library that is already put together that enables us to use the twitter API. It's called python-twitter.
After you have installed python, install the python-twitter library and all its dependencies. If you run into trouble just consult the documentation over on the python-twitter website.
Next, install the Arduino IDE so you can program your arduino and talk to it via serial port.
Once those are set up and working, time to go grab your credentials from twitter.com
Step 3: Setting Up Twitter
Interfacing with twitter used to be easy, all you had to do was put your name and password into your code and it would work. Now twitter has taken user info more seriously using oAuth, and as a result now you must register your app with twitter and get an API key.
First, make a twitter account for this project that is separate from your main twitter account. I chose, driptwit.
Then, go to dev.twitter.com and register your app, this will enable you to grab 4 important pieces of information
-Access Token
-Access Token Secret
-Consumer Key
-Consumer Secret
These keys will be needed in the python code later to interface with the twitter API. After you have those 4 codes, you should be able to continue.
Step 4: The Code: Python Side
First lets go over our python code. The python code basically uses the python-twitter library to ask twitter for the statuses of user "x", it then takes the last status and searches for the term "#driptwit".
if found sends the ascii value of 1 to the serial port (and to the arduino), if #driptwitstop is found, it sends an ascii value of 0.
Lastly it loops and checks the twitter account every 15 seconds looking for changes.
As you can see, below is where you enter the keys you got from twitter in the last step.
Here is the actual code:
# Tweet-a-Pot by Gregg Horton 2011 #
# Please email changes or #
# updates to greggahorton@gmail.com #
##Import Libraries
import twitter
import serial
import time
##authenticate yourself with twitter
api = twitter.Api(consumer_key='consumerkeyhere', consumer_secret='consumersecrethere', access_token_key='accesskey', access_token_secret='accesssecret')
##set to your serial port
ser = serial.Serial('/dev/ttyUSB0', 19200)
## check serial port
def checkokay():
ser.flushInput()
time.sleep(3)
line=ser.readline()
time.sleep(3)
if line == ' ':
line=ser.readline()
print 'here'
## Welcome message
print 'Welcome To Drip Twit!'
print 'Making Coffee..'
def driptwit():
status = [ ]
x = 0
status = api.GetUserTimeline('X') ##grab latest statuses
checkIt = [s.text for s in status] ##put status in an array
drip = checkIt[0].split() ##split first tweet into words
## check for match and write to serial if match
if drip[0] == '#driptwit':
print 'Tweet Recieved, Making Coffee'
ser.write('1')
elif drip[0] == '#driptwitstop': ##break if done
ser.write('0')
print 'stopped, awaiting instructions.'
else:
ser.write('0')
print 'Awaiting Tweet'
while 1:
driptwit() ## call driptwit function
time.sleep(15) ## sleep for 15 seconds to avoid rate limiting
Step 5: The Code: Arduino Side
The only connection between the python code and arduino is a single serial value. Python sends this as an ascii value, so arduino interprets this as a bit number, in our case 1= 49.
I didn't know how to make python spit out serial bytes, so after seeing what the python code was sending, i just modified the arduino code to react to the right value.
Here is the code:
Tweet-a-pot Gregg Horton 2011
Please email changes to greggawatt@instructables.com so i
can improve this code!
Enables blinking/relay control over twitter, using python code
Based off of Blink and Serial demo code
int relayPin = 13; // LED connected to digital pin 13
int incomingByte = 0; //declare incoming byte
// The setup() method runs once, when the sketch starts
void setup() {
// initialize the digital pin as an output:
pinMode(relayPin, OUTPUT);
Serial.begin(19200); // set up Serial library at 19200 bps
Serial.println("Arduino is ready!");
// the loop() method runs over and over again,
// as long as the Arduino has power
void loop()
if (Serial.available() > 0) {
// read the incoming byte:
incomingByte = Serial.read();
Serial.println(incomingByte);
if (incomingByte == 49){
digitalWrite(relayPin, HIGH);
} else {
digitalWrite(relayPin, LOW);
// say what you got:
Serial.print("I received: ");
Serial.println(incomingByte, DEC);
Step 6: Hardware Setup
The hardware set up is pretty simple, as the AC voltage control is being handled by the power switch tail
The power switch tail allows you to hook up 2 wires, one to ground and one to the control pin, to turn on and off the relay. As seen in the code, all you need is a simple high/low statement.
Connect the arduino to your computer and make sure your serial port is set, then plug the power switch tail leads into pin 13 and ground
Next connect the coffee pot to the relay and plug the relay into a regular outlet. Its that easy!
The coffee maker has to have coffee and water in it as well before you begin.
Step 7: Make Some Coffee
I did a lot of testing before hooking this up to an actual coffee pot (and even then found some bugs), but once you get it working, its time to make coffee!
Fill the pot with water and coffee grounds, and tweet to the account the code is following.
If the message contains the word #driptwit the coffee will start, if it receives #driptwitstop, or you tweet something else it will stop.
Once the pot of coffee is done, tweet again to turn it off. Its that easy!
Then enjoy your hot piping cup of tweet coffee.
Step 8: Final Thoughts
This project can be extended to any AC device that you want to control remotely. You could turn on lights or open garage doors with the same concepts
The code is not perfect, any improvements that people give me i will gladly include and test out. A large improvement on this project would be to integrate an ethernet shield so you wouldn't have to have a dedicated computer.
I want to give special thanks to the team the developed the python-twitter library, without them this project would be much harder.
  • Woodworking Contest
    Woodworking Contest
  • Microcontroller Contest
  • Make it Move Contest
99 Comments
ı want to ask somethink, the output of the power switch going to the coffee machine, but you cannot tell from the photo attached where the input ends
how can we make it without using power tail as I live in India and here it is not available
Lovely idea!
New to the Arduino world. Having trouble uploading the code to the Arduino board. Also where do I input the Access Tokens and Consumer Key?
I will try this out , cause was the first thing that came to my mind when knowing about arduino for the first time...it is great somebody else did it already!!
Thats what I am currently making.
I am using Raspberry Pi 2 instead of laptop and according to me it definetely would.
cant u just just rapsberry Pi 2? do u need arduino here?
Hummm? Can the Arduino IDE run in Linux(Raspberry Pi). That is a good question.
There is Arduino IDE available for raspberry pi.(Raspian)
To get it use command sudo apt-get install arduino
Is it still working ? I ve heard that twitter changed some policy or something.
How do I program the part that adds water and coffee?
To connect to the serial port i use this code instead of the suggested one because allows to search in more than one serial port :D
#to use with linux locations = ['/dev/ttyACM0', '/dev/ttyACM1', '/dev/ttyACM2']
locations = ['COM3','COM4','COM5','COM6'] #to use with windows
for device in locations:
try:
ser = serial.Serial(device, baudrate=9600, bytesize=8,
parity=serial.PARITY_NONE, stopbits=serial.STOPBITS_ONE)
print ("\nArduino found on: " + ser.portstr + " please wait...\n")
time.sleep(2)
break
except:
print "Failed to connect on", device
Great idea. Thanks for sharing us
