Tweeting Cat Door
 by e1ioan
Contest WinnerFeatured
Note: to see everything on one page, please go to: www.tweetingcatdoor.com
After receiving many emails requesting Instructions and Kits for building the "Tweeting Cat Door ", I decided to make a version that is stand-alone and doesn't need a computer to be run and that is easy to be put together by anyone with a soldering iron and a little time on hand. All the software is available to download, but feel free to modify it to make it better or to better suit your needs.
The Tweeting Cat Door works as follows:
When a pet tries to enter the pet door, a RFID reader will read the RFID tag that your pet has on the collar. If the tag is authorized , the latch of the pet door will open, a picture is taken of the pet, and uploaded to Twitter along with a funny random message, for example: "Penny is in playing with a ball of yarn."
The pet door works in the same way when the pet tries to go out. A picture is taken and uploaded to Twitter along with a message, for example: "Gus is out to play poker with the fellas."
The messages are chosen at random from a list of possible messages.
Here are some examples:
http://twitpic.com/2a7q32
http://twitpic.com/2uehbs
http://twitpic.com/2uc1ry
http://twitpic.com/29jcd2
Here is @GusAndPenny  Sadly, there are no recent updates @gusandpenny. Gus died a while back (probably a fight with a raccoon or other cats?) and not long after, Penny followed.
Note: The twitter part of the project is optional. You can just build the Arduino controller, the latch to lock/unlock the pet door, mount the RFID reader and the latch on the door and you are ready to go. Your pets would be "sorted" by the RFID tag they are waring.
Here you'll find detailed step by step instructions and kits with all the components (you can buy kits, PCB, preprogrammed Arduino chip, etc, by contacting me). By following the instructions on this page, you will have - in no time - your own RFID enabled, twitting pet door, just like the original Tweeting Cat Door.
How does the RFID (Radio-frequency identification) enabled pet door works?
Each pet will have a small RFID tag on the collar and the pet door will open ONLY for your pet for entering the house.
The RFID enabled pet door has 3 settings that can be controlled by pressing a button. For each setting a LED will light in a different color:
GREEN - Open, your pet is allowed to exit the door and to enter the door.
BLUE - In-only, your pet is allowed to only enter the door (for example at night when you want your pet inside)
RED - Locked, the door will stay locked and no exit or entering is allowed.
Note: The entering through the door is controlled by RFID, exiting is controlled by a infrared beam.
Step 1: Make your own!
The pet door controller  is based on ATmege328 chip with Arduino bootloader. In this tutorial we won't use an already made Arduino board, we will build our own customized one to fit just our needs.
Note: You are welcome to use your own Arduino board. If you look at the schematic it would be very easy to build it around a standard Arduino board, but we won't cover it in this article.
Here is the schematic for the pet door controller we will use (click on the image to zoom in).
And if you want to see the PCB board design, click on following links:
The schematic
Top Layer with Silkscreen
Top Layer
Bottom Layer
(if you want to make your own PCB board, check out this)
You can also download the Eagle files at the bottom of this page.
On the schematic, you will see a bunch of header connectors, here is the description for each of them:
VCC1 : connect the power supply here
ICSP : you will use this for uploading your software to the Arduino chip.
IRT : the Infrared transmiter LED goes here
IRD : the infrared detector
WIFI : serial connection that goes to the OpenWrt router
RFID : your RFID reader (the software supports both ID12 and Parallax readers, selectable from RJP)
BTN : button to control the way the door operates (open, in only, locked)
RGB : RGB LED (common anode, common cathode, both work, selectable from JP1)
SERVO : the servo that will open/close the pet door latch
SETSERVO button : when pressed you are going to be able to set the max values the servo goes to right or left. The settings are made using the trimpots TPR (max right) and TPL (max left).
PROGTAG button : when pressed, arduino will switch in "learning mode" and you can program new RFID tags. The tags are "learned" by passing them in front of the reader.
JP2: disconnects the RFID reader from the serial, and this way the ICSP can be used to reprogram arduino chip.
1-40 of 45Next »
waldy says: Jun 23, 2011. 7:07 AM
Hi pdxnats & Fun2hold comments earlier. Congratulations, I believe have something quite special here. You may not realise but you may have a seed of an idea here that may have far reaching consequences. Here you have a building block to advancing AI (Artificial Intelligence)
I better explain briefly (bear with me): You have given your lovely moggy a way of communicating with the whole world, without even realising it herself. AI is of no use socially if it does not interact with us or animals. Now, I'm not too sure where this is going, however I do know that I have lots of ideas for this concept that could make your moggy talk to the world in a more expressive and articulate way. Drop me a message with your mail address, It would be fun to talk.
ps without doubt, an all time best instructable with potential that could blow your mind!
huangleihe in reply to waldyJul 1, 2011. 6:16 PM
I COME from China ,I can't understand whato you say ,but i love eletrion
中文,你能看懂吗,有会中文的网友吗?
pdxnat says: Jun 28, 2011. 10:22 AM
This is just awesome. Not only is it a very well written instructable, but it involves hacking a router and creating a standalone twitter-enabled sensor-camera. I haven't tried building it yet--I'm a little intimidated by it--but this is the best example of its type I've seen. Thanks for posting it!!!
e1ioan (author) in reply to pdxnatJun 28, 2011. 6:42 PM
Thank you. If you have questions or some details are not clear, let me know.
aattura1 says: Jun 28, 2011. 1:58 PM
Well, my enthusiasm is dampened by the outcome for those two poor cats -- so sorry! The Great outdoors is not at all great for innocent beings who are at the mercy of anyone or anything that comes along (The word ManKIND is far too often an Oxymoron). A tamper-proof cat enclosure- good idea-- but letting your cat out? The world has changed alot-- it's like letting your 2 yr old out without supervision.
e1ioan (author) in reply to aattura1Jun 28, 2011. 6:41 PM
I can assure you we were responsible pet owners. By no means would I equate cats to a human child regardless of how much our cats meant to us: ) Our cats had wonderfully full lives being indoor/outdoor. Gus passed away likely due to an encounter with a predator, a very natural death for an animal and Penny passed due to old age. The cat door offers solutions for pet owners with a multitude of obstacles and needs for their pets; indoor and outdoors.
foobear says: Jun 23, 2011. 6:31 AM
Not only is this awesome, but I NEED IT NOW!!!
I've been waiting for a manufacturer to make an RFID cat door. (mind boggles as to why it still does not exist). And here you have just handed it to us, thank you.
One million percent awesome!
e1ioan (author) in reply to foobearJun 27, 2011. 9:29 AM
Thank you!
vcote in reply to foobearJun 23, 2011. 3:22 PM
RFID pet doors have existed for years. For cats and dogs. The modification here is to make it tweet as well as unlock the door for your pet. Imagine how practical as well as fun. My husband is afraid to let the petdoor unlocked when we are not home, even if the yard is fenced. "We never know". Whit this system, we can monitor the dog's coming and going and monitor how long they spend out. If it seems too long (they never go longer than half an hour in the summer and 5 seconds in the winter) I can call the old lady neighbor or a friend and ask to check on them.
What I am waiting for is a RFID door I can easily program to scan the RFID chip already imbedded in the dog's skin in case it gets lost/found. I bet e1loan can figure it out...? :)
foobear in reply to vcoteJun 25, 2011. 5:43 AM
Yes I suppose I knew that those existed, but I didn't try very hard to find one. I looked on Amazon but they only have those ones that require the cat to wear a heavy awkward dangly magnet. My cat goes collarless so I haven't bothered with those.
GeoLeoX in reply to foobearJun 23, 2011. 7:08 AM
There are about a half dozen commercially-made RFID doors, some fancier (and more expensive than others). I installed one that reads the sub-q embedded microchip for each of our two cats.
vcote in reply to GeoLeoXJun 23, 2011. 3:24 PM
Oh! What is the brand? I can't find one. Does it work well? Does it let the cold/hot in when it is closed?
GeoLeoX in reply to vcoteJun 23, 2011. 4:17 PM
I don't know of a product that would work for implanted chips in dogs. The reason the one for cats works is because they have no problem going in a door not much bigger than their head. I have a SureFlap, but there are others. The cat has to put it's head into the "chute" in order for the sensor to detect the chip. It requires very close (1-2 inches) of proximity.
e1ioan (author) in reply to GeoLeoXJun 23, 2011. 11:19 AM
What's the fun in buying stuff if you can make it yourself and learn a lot in the process?
9ale7 in reply to e1ioanJun 24, 2011. 4:54 AM
Exactly !!
GeoLeoX in reply to e1ioanJun 23, 2011. 12:26 PM
You are absolutely right and I am absolutely lazy.
graemeh in reply to GeoLeoXJun 23, 2011. 2:56 PM
You are not the only lazy one!
I suppose to redeem myself I should hack in to the flap I've bought to add tweeting and data logging of entry/exit times :)
overblast in reply to GeoLeoXJun 23, 2011. 8:04 AM
Oh, that is *awesome*! Our cat does not wear a collar (ever try to get a collar on a highland lynx?), but does have the chip embedded in his body, this is perfect!
ljacoby714 says: Jun 23, 2011. 9:44 AM
Am I the only one who is troubled by the sad connection between letting cats out —unleashed and unsupervised—and "Gus died a while back (probably a fight with a raccoon or other cats?) and not long after, Penny followed"?
dronex in reply to ljacoby714Jun 24, 2011. 1:27 AM
Not all cats fare equally outdoors. My neighbors cats have been indoor/outdoor cats for well over ten years, no problem. A lot of factors to consider.
sparkton in reply to dronexJun 25, 2011. 10:19 PM
Stats show "indoor" cats live twice as long (on average) as in&out cats; pretty straightforward.
vcote in reply to ljacoby714Jun 23, 2011. 3:33 PM
I have a fenced yard. The dogs can't go in. But if a raccoon wanted to come in, it could easily. I am not pro letting cats roam free willing either, but I wouldn't go around pointing fingers. Sometimes we do things that we think are ok, and then somethings happens and make us realize it was a mistake. (Ever try to light up a fart at 15 or something stupid like that?)
That said, here is a picture of the stray we took in last winter. He was in very bad shape, but just the nicest. Sadly, he didn't make it; I wish he had come to me earlier. R.I.P Skinny Jim.
fungus amungus in reply to ljacoby714Jun 23, 2011. 10:17 AM
I'd like more information about supervising a cat outdoors. Is that possible?
annagail in reply to fungus amungusJun 23, 2011. 11:08 AM
I wasn't gonna get into this debate, but I actually have a response to this. I take my indoor cat out on a harness. She doesn't mind a bit- I don't "walk" her as much as she walks me and I try to pretend like I'm not there. She climbs, scratches, sniffs, and has a great time.
fungus amungus in reply to annagailJun 23, 2011. 12:17 PM
No problem, I've seen that before. I was wondering if those were discrete actions. As in you could supervise w/o a leash or harness.
I let my cats out and they often don't even come back at night. Don't mind others keeping cats indoors, just their choice.
annagail in reply to fungus amungusJun 23, 2011. 1:33 PM
I guess we do kind of do that with our other cat, actually. He is young, and timid & skittish by nature. He doesn't like the harness at all, so we just take him outside our front door and put him down and watch him. It's not really enclosed but there are only two easy escape routes which we sort of causally guard- once again the idea is to sort of pretend we're not there and let him do his own thing while enjoying the outdoors. He is naturally nervous so he doesn't run off or climb up anything or try to escape, just sniffs at things and rolls on the ground in the sun and other cat things.
I'm not one of those people who sees this issue in black and white, either- I just decided to keep my cats in because my neighborhood is not cat-friendly, they don't seem to mind mostly staying inside, and they get tons of exercise playing with their humans & each other.
To the original poster sorry about all the OT chatter :D
benwade in reply to ljacoby714Jun 23, 2011. 9:56 AM
Gotta love people who love to CONTROL their pets. Have you ever heard of quality-of-life? I could probably make sure you lived to be a hundred. Daily enforced exercise, extreme calorie restriction, no dangerous activities, etc. But you wouldn't stand for it. Why would you impose it on animals? Because it makes your little control-freak heart happy. Oh, and you get to be holier than thou all over everyone else...
mwotton in reply to benwadeJun 23, 2011. 7:10 PM
Here in Australia, it's more important to control cats because they are a significant threat to native wildlife, and less about the safety of the cat. Cat owners, it should be illegal to allow your cat out at night. Your cat's well-being is not more important than the well-being of the native birds it will kill while they sleep.
Besides, there's nothing worse than waking up to find that your neighbour's good-for-nothing cat has urinated all over your front door mat. That says 'Welcome to my house' in a distinctly unpleasant manner.
With all that in mind, I am thinking of making one of these for my neighbour, only instead of a switch controlling the lock, it would be time based to prevent the cat from getting out at night.
davidqxo says: Jun 23, 2011. 6:37 AM
How about recognition software for the camera to bar entrance when kitty is trying to bring in something vile?
foobear in reply to davidqxoJun 25, 2011. 5:38 AM
e1ioan (author) in reply to davidqxoJun 23, 2011. 9:19 AM
You could put an electronic scale at the entrance and see if your pet is heavier than normal :-) (of course you have to consider the extra weight when your pet is wet)
mpep in reply to e1ioanJun 23, 2011. 11:51 AM
With the use of a humidity sensor, you can then have an acceptance weight range, and hence no problems. Just a thought.;-)
e1ioan (author) in reply to mpepJun 23, 2011. 12:07 PM
... and if the scale is one of the clear glass kind, you could install a scanner under, to take a picture of your pet's feet to see if they are dirty or not :-)
AmyLuthien says: Jun 23, 2011. 3:52 PM
I have constant problems on a large and expensive scale because my neighbors let their cats roam loose. Well, one cat now, coyotes got the other cat a few months back.
So cat owners, PLEASE, keep your cats under control! Us dog owners manage it, so can you. Besides, death by being torn apart by a coyote or a raccoon would be horrifying, can you imagine dying that way? I can't, and I sure wouldn't want it for my pets either.
But otherwise, this is a pretty awesome 'ible!
lambsb says: Jun 23, 2011. 2:06 PM
Very nice. I'm getting to like this rfid stuff. Would be a great way for a robot to identify its location or access areas of a house. I've been thinking about writing an 'ible on motion based webcam/email security system. Maybe I'll do that. As for the cats, our cat was in and out often until finally he just stays outside except to eat etc. He hasn't expired yet. (We do live in the country though)
savvychic says: Jun 23, 2011. 12:18 PM
Hey.....this could work for the kids, too!
lesizz says: Jun 23, 2011. 11:56 AM
Great project. If you'd like to build on it, I have suggestions.
1. Many cats come equiped with an RFID chip installed by the Vet. How about designing your invention to work on these chips?
2. Enable different in-out settings for 2 or more cats.
3. Logging ability: Produce a log of when kitter goes in and out.
Thanks for this project!
mikeythev says: Jun 23, 2011. 6:25 AM
This is a fantastic project! Who doesn't love the Arduino, and is there anything it can't do? I lack many of the genius skills I read about here in Instructables, but my dream project would be a cat food bowl RFID device. With two cats, one always eats the other cat's food. We have one skinny cat, and one not-so-skinny cat.
Outstanding job friend!!!
lesizz in reply to mikeythevJun 23, 2011. 11:48 AM
There is a rfid cat feeder in instructables. It uses the dvd tray in a discarded dvd drive as the hatch. look for it
waldy in reply to mikeythevJun 23, 2011. 7:14 AM
Hey Mike, I'm the other way round* and believe there is huge potential for the ideas raised in this project. Outline the ideas you would like, I'll have a smoke, and maybe a beer or two on the deck.. & I'll try explain how you would acheive it
You'll just need to know how to do the clever stuff with the Arundo & put in practise what I suggest. What'ya say, an instructable partnership? If your interested mail me.
* I'm a little practically lacking and a goldfish attention span!
1-40 of 45Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
