Introduction: Twin Hearts Wire Ring for Your Valentine
"I feel it in my fingers I feel it in my toes, the love that's all around me And so the feeling grows."
All you love filled hearts,
Tell me that you are feeling like these amazing lines from the the song "Love is all around" from Wet wet wet. Because I do. And because of that my creativity factor seems like working in full form.
A few days back I published this ible for a Valentine's Day Heartbeat necklace and all you amazing people loved it. Thank you so much. Since then the idea of making hearts using wires got stuck in my mind and today I came up with this beautiful wire ring which I call "Twin Hearts Ring". I think it will be a wonderful companion to the Heartbeat necklace.
And you know it is easy to make too.. sounds like fun? Lets get started.
P.S: Dear instructables, Thank you letting me know that I can make jewelry too, which I had never imagined in my life ever.
Step 1: Simple Stuff You Need
Some pliers like round nose, flat nose and wire cutter
A mandrael or some round object of varying thickness
Two types of jewelry wire (copper, steel or silver your choice), see image above to have an idea:
- Thick wire: 18-20 gauge
- Thin wire: 30-32 gauge (for wrapping)
- Lots of love in your heart :)
Yup that's all you need :).
Step 2: Make Twin Hearts
See images above and follow:
You would need two pieces of thick wire
- For outer heart : around 6"
- For inner heart: around 5"
Start :
- Pick long wire and bend it to find its middle.
- Wrap the wire from middle around the mandrel's top (the thin part), target to make a loop around 1cm diameter.
- both ends of wire should intersect each other.
- Take out the wire from mandrel and hold the loop from middle using flat nose plier.
- Using your hand bend the wire from right by pulling it upwards, notice the heart shape is forming.
- Release the plier and pull both wires intersecting each other such that they form the heart shape.
- Use your finger to squeeze the heart , it you think it is bigger. This will also help to shape the heart properly.
- Using flat nose plier, bend the wires downwards from where they are intersecting such that they form legs of the heart , see image.
Pick small wire and repeat the steps to make a smaller heart.
Now comes the easy part :)
Step 3: Wrapping Two Hearts Together :)
IMPORTANT: I have learned that while making wire jewelry, it is important not to leave any open ended wires because they may scratch your skin or get stuck with your cloths. I will tell you how to hide the wire ends here for safety.
- Put the smaller heart inside the bigger heart and flatten the wire inside such that 4 wires are parallel to each other.
- Now grab the thin wire.
- NOTE: We don't want to expose the end of thin wire, so we will also wrap it inside.
- Insert the thin wire from behind the heart and bend it parallel to other wires (See image, where I am holding the arrangement)
- Start wrapping tightly and without any gaps. Make sure the wires are parallel (not overlap) as you progress.
- When you wrapped half of the wire, stop.
- Where the wires end, cut the two wires inside to make them slightly smaller then the outer wires.
- Using the flat nose plier, bend the outer wires to form a inward u-turn. We are doing this to secure the sharp ends of the wire inside wrap.
- Complete the wrap till the end leaving just a bit such that the two bended loops are visible
- Insert the thin wire in one of loops and cut it as close as possible to the thick wire.
Almost there... :)
Step 4: Shape of Your Heart
Wrap the straight arrangement around the mandrel fully, leaving just about 1/2cm of space between the ends.
This ring can also be wore as thumb ring, so if you want to wear it like that, wrap it around the larger part.
Yayyyyyy!!!!! You just made an awesome ring for your valentine.
Did you like this ible? Please share it , comment it, make it.
Loved it ? Please Vote it :)
You are Awesome :)
Stay tuned.
