Step 2Christmas Tree : Step-by-Step Instruction
The first thing we need to do is to cut trees, stars, and a pocket using templates. You can download the template pdf file in below URL.
Christmas Tree Template download
Fold a piece of paper in half and place the templates. Cut outside using scissors and cut inside using a blade.
2. attach tree shapes using a tape
Connect the tree papers using tape. So, when you complete and are ready to connect, it will actually stand-alone.
3. band legs of 8 LEDs
We will attach the LEDs on the tree. We have 8 LEDs and we will wind wires on the LEDs' legs. Band the legs of the LED to the outside.
4. wind wires on LED legs
When you finished band the legs of LEDs, band wires on the legs. The white wires will be attached to the positive leg of LED and the yellows wires will be attached to the negative leg of LED. There are two ends of wires which are striped one long and one short. Band the one stripped wire around the LED legs.
5. push the wires through middle of each tree
We will insert the LEDs in the middle of the tree. Make a little hole using a blade in the middle of the tree and push the wires through the hole and pull out the wires. Insert the wires in each section of the tree and pull out the wires to one section of the tree.
6. divide the wires to negative and positive
In this side you can see the all wires come out. We need to divide wires positive and negative. You can divide white wires for positive group and yellow wires for negative group.
7. tie wires and attach them on the tree
Tie the yellow wires together and attach them to the right side using a glue gun and then, tie the rest of the white wires and attach them to the left side.
8. attach the paper to hold coin battery
Now, we will make a pocket for inserting a coin battery. Place the coin battery over the negative wires and attach the pocket using a hot glue gun over the battery. Make sure the pocket should hold the battery tightly. When you close the tree, you should see the LEDs light up.
9. attach Velcro to touch negative wires with battery
Attach a set of Velcro on the top and bottom of the pockets and on the other side of the tree as well. We are almost done!
10. insert the 3v coin battery
Insert the 3V coin battery into the pocket so that the positive side of battery will touch the other side of wires though a hole of the pocket.
11. Finish!
When you close the Velcro, see the lighting is turned on!
Enjoy~
If you need more information for making it, please visit TechDIY.orgsite.
Add Comment
