Twitter Controlled Pet Feeder by amandaghassaei
Featured
Step 8: Solder white LEDs and current limiting resistors
Solder two 100ohm resistors to the protoboard.  One resistor should be electrically connected to the header pin for arduino digital pin 2 and the other resistor to digital pin 3 (figure 2).  Bend the leads of two white LEDs and solder to the copper side of the protoboard as shown in figures 3 and 4.  Solder a (red) jumper wire between each of the 100ohm resistors and the anodes of each of the white LEDs (figures 5 and 6).  Solder two (black) jumper wires between the cathodes of both LEDs and the to arduino ground (figure 7 and 8).
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
