3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Twitter Mood Light - The World's Mood in a Box
Step 10Programming step 4: RGB LED
A simple library for setting the colour of an RGB LED. The library will fade between the colours as the world mood changes, and will flash if it is a significant change in mood.
*** update ***
If you find the colours look wrong, try removing the "255 -" from the analogWrite calls.
Thanks to shobley for finding this.
More info at http://www.stephenhobley.com/blog/2010/06/11/arduino-world-mood-light-using-twitter-and-wishield/
*** end update ***
 The led is initially set to be currentColorID and over time will fade
 to desiredColorID with a time delay, fadeDelay, measured in ms, between
 each step. No effort is made to scale the step size for each rgb
 channel so each may not complete at the same time.
void LED::FadeTo(int desiredColorID)
      // check for valid colorID
 if (desiredColorID >= NUM_COLORS ||
      desiredColorID < 0)
      //logger.log("invalid Color id")
      return;
 // get a local copy of the colors
 Color currentColor;
 currentColor.r = Colors[m_currentColorID].r;
 currentColor.g = Colors[m_currentColorID].g;
 currentColor.b = Colors[m_currentColorID].b;
 Color desiredColor;
 desiredColor.r = Colors[desiredColorID].r;
 desiredColor.g = Colors[desiredColorID].g;
 desiredColor.b = Colors[desiredColorID].b;
 bool done = false;
 while (!done)
    // move each of r,g,b a step closer to the desiredColor value
    if (currentColor.r < desiredColor.r)
      currentColor.r++;
    else if (currentColor.r > desiredColor.r)
      currentColor.r--;
    if (currentColor.g < desiredColor.g)
      currentColor.g++;
    else if (currentColor.g > desiredColor.g)
      currentColor.g--;
    if (currentColor.b < desiredColor.b)
      currentColor.b++;
    else if (currentColor.b > desiredColor.b)
      currentColor.b--;
    // write the new rgb values to the correct pins
    analogWrite(m_redPin, 255 - currentColor.r);
    analogWrite(m_greenPin, 255 - currentColor.g);
    analogWrite(m_bluePin, 255 - currentColor.b);
    // hold at this color for this many ms
    delay(m_fadeDelay);
    // done when we have reach desiredColor
    done = (currentColor.r == desiredColor.r &&
            currentColor.g == desiredColor.g &&
            currentColor.b == desiredColor.b);
 } // while (!done)
 m_currentColorID = desiredColorID;
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:RandomMatrix
