3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Twitter Mood Light - The World's Mood in a Box
Step 6Download the code
Download the code
The attached WorldMood.zip contains 4 subdirectories (or "libraries") and the Arduino sketch WorldMood.pde
The four libraries need to be copied into the Arduino library directory and then they can be imported as shown.
WorldMood/WorldMood.pde (see below) should be opened in the Arduino development environment.
You then need to correct the "[your network]" and "[your network password]" fields. eg.
#define network ("mynetwork")
#define password ("mypassword")
Then the sketch (and libraries) should be compiled and uploaded to the Arduino board.
see arduino.cc/en/Hacking/LibraryTutorial
The next 5 programming steps just give an overview of each of the components and include the most noteworthy parts of the source code...
**** Update ****
If you have a newer board then you may need to change this
struct SPI_UART_cfg SPI_Uart_config = {0x50,0x00,0x03,0x10};
to this:
struct SPI_UART_cfg SPI_Uart_config = {0x60,0x00,0x03,0x10};
See here for more info:
http://forum.sparkfun.com/viewtopic.php?f=13&t=21846&sid=24282242d4256db0c7b7e814d7ca6952&start=15
http://www.sparkfun.com/commerce/product_info.php?products_id=9367
***** End Update ****
// LED setup - only some pins provide 8-bit PWM (Pulse-width modulation)
// output with the analogWrite() function.
// http://www.arduino.cc/en/Main/ArduinoBoardDuemilanove
// PWM: 3,5,6,9,10,11
#define redPin    (3)
#define greenPin (5)
#define bluePin   (6)
// delay in ms between fade updates
// max fade time = 255 * 15 = 3.825s
#define fadeDelay (15)
// Wifi setup
#define network ([your network])
#define password ([your network password])
#define remoteServer ("twitter.com")
const char* moodNames[NUM_MOOD_TYPES] = {
 "love",
 "joy",
 "surprise",
 "anger",
 "envy",
 "sadness",
 "fear",
const char* moodIntensityNames[NUM_MOOD_INTENSITY] = {
 "mild",
 "considerable",
 "extreme",
// the long term ratios between tweets with emotional content
// as discovered by using the below search terms over a period of time.
float tempramentRatios[NUM_MOOD_TYPES] = {
 0.13f,
 0.15f,
 0.20f,
 0.14f,
 0.16f,
 0.12f,
 0.10f,
// these numbers can be tweaked to get the system to be more or less reactive
// to be more or less susceptible to noise or short term emotional blips, like sport results
// or bigger events, like world disasters
#define emotionSmoothingFactor (0.1f)
#define moodSmoothingFactor (0.05f)
#define moderateMoodThreshold (2.0f)
#define extremeMoodThreshold (4.0f)
// save battery, put the wifly to sleep for this long between searches (in ms)
#define SLEEP_TIME_BETWEEN_SEARCHES (1000 * 5)
// Store search strings in flash (program) memory instead of SRAM.
// http://www.arduino.cc/en/Reference/PROGMEM
// edit TWEETS_PER_PAGE if changing the rpp value
prog_char string_0[] PROGMEM = "GET /search.json?q=\"i+love+you\"+OR+\"i+love+her\"+OR+\"i+love+him\"+OR+\"all+my+love\"+OR+\"i'm+in+love\"+OR+\"i+really+love\"&rpp=30&result_type=recent";
prog_char string_1[] PROGMEM = "GET /search.json?q=\"happiest\"+OR+\"so+happy\"+OR+\"so+excited\"+OR+\"i'm+happy\"+OR+\"woot\"+OR+\"w00t\"&rpp=30&result_type=recent";
prog_char string_2[] PROGMEM = "GET /search.json?q=\"wow\"+OR+\"O_o\"+OR+\"can't+believe\"+OR+\"wtf\"+OR+\"unbelievable\"&rpp=30&result_type=recent";
prog_char string_3[] PROGMEM = "GET /search.json?q=\"i+hate\"+OR+\"really+angry\"+OR+\"i+am+mad\"+OR+\"really+hate\"+OR+\"so+angry\"&rpp=30&result_type=recent";
prog_char string_4[] PROGMEM = "GET /search.json?q=\"i+wish+i\"+OR+\"i'm+envious\"+OR+ \"i'm+jealous\"+OR+\"i+want+to+be\"+OR+\"why+can't+i\"+&rpp=30&result_type=recent";
prog_char string_5[] PROGMEM = "GET /search.json?q=\"i'm+so+sad\"+OR+\"i'm+heartbroken\"+OR+\"i'm+so+upset\"+OR+\"i'm+depressed\"+OR+\"i+can't+stop+crying\"&rpp=30&result_type=recent";
prog_char string_6[] PROGMEM = "GET /search.json?q=\"i'm+so+scared\"+OR+\"i'm+really+scared\"+OR+\"i'm+terrified\"+OR+\"i'm+really+afraid\"+OR+\"so+scared+i\"&rpp=30&result_type=recent";
// be sure to change this if you edit the rpp value above
#define TWEETS_PER_PAGE (30)
PROGMEM const char *searchStrings[] =
 string_0,
 string_1,
 string_2,
 string_3,
 string_4,
 string_5,
 string_6,
void setup()
 Serial.begin(9600);
 delay(100);
void loop()
 // create and initialise the subsystems
 WiFly wifly(network, password, SLEEP_TIME_BETWEEN_SEARCHES, Serial);
 WorldMood worldMood(Serial, emotionSmoothingFactor, moodSmoothingFactor, moderateMoodThreshold, extremeMoodThreshold, tempramentRatios);
 LED led(Serial, redPin, greenPin, bluePin, fadeDelay);
 TwitterParser twitterSearchParser(Serial, TWEETS_PER_PAGE);
 wifly.Reset();
 char searchString[160];
 while (true)
    for (int i = 0; i < NUM_MOOD_TYPES; i++)
      twitterSearchParser.Reset();
      // read in new search string to SRAM from flash memory
      strcpy_P(searchString, (char*)pgm_read_word(&(searchStrings[i])));
      bool ok = false;
      int retries = 0;
      // some recovery code if the web request fails
      while (!ok)
        ok = wifly.HttpWebRequest(remoteServer, searchString, &twitterSearchParser);
        if (!ok)
          Serial.println("HttpWebRequest failed");
          retries++;
          if (retries > 3)
            wifly.Reset();
            retries = 0;
      float tweetsPerMinute = twitterSearchParser.GetTweetsPerMinute();
      // debug code
      Serial.println("");
      Serial.print(moodNames[i]);
      Serial.print(": tweets per min = ");
      Serial.println(tweetsPerMinute);
      worldMood.RegisterTweets(i, tweetsPerMinute);
    MOOD_TYPE newMood = worldMood.ComputeCurrentMood();
    MOOD_INTENSITY newMoodIntensity = worldMood.ComputeCurrentMoodIntensity();
    Serial.print("The Mood of the World is ... ");
    Serial.print(moodIntensityNames[(int)newMoodIntensity]);
    Serial.print(" ");
    Serial.println(moodNames[(int)newMood]);
    led.SetColor((int)newMood, (int)newMoodIntensity);
    // save the battery
    wifly.Sleep();
    // wait until it is time for the next update
    delay(SLEEP_TIME_BETWEEN_SEARCHES);
    Serial.println("");
1 comment
Oct 20, 2011. 3:23 PMbenreed says:
hey awsome project :) but i keep getting error messages on the code? i have never built a project with code before so i have no idea what im doing , i have a fairly good knowladge of computers however , you think you can help?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:RandomMatrix
