3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Twitter Mood Light - The World's Mood in a Box
Step 8Programming step 2: Connecting to a Wireless Network
Again, this is largely based on the sparkfun tutorial, but I've removed the delays with "waits for response". This speeds things up and is easier to error check.
www.sparkfun.com/commerce/tutorial_info.php
 Send the correct commands to connect to a wireless network using the parameters used on construction
void WiFly::AutoConnect()
 delay(DEFAULT_TIME_TO_READY);
 FlushRX();
 // Enter command mode
 EnterCommandMode();
 // Reboot to get device into known state
 WriteToWiFlyCR("reboot");
 WaitUntilReceived("*Reboot*");
 WaitUntilReceived("*READY*");
 FlushRX();
 EnterCommandMode();
 // turn off auto joining
 WriteToWiFlyCR("set wlan join 0");
 WaitUntilReceived(AOK, ERR);
 // Set authentication level to
 WriteToWiFly("set w a ");
 WriteToWiFlyCR(auth_level);
 // Set authentication phrase to
 WriteToWiFly("set w p ");
 WriteToWiFlyCR(m_password);
 // Set localport to
 WriteToWiFly("set i l ");
 WriteToWiFlyCR(port_listen);
 // Deactivate remote connection automatic message
 WriteToWiFlyCR("set comm remote 0");
 // Join wireless network
 WriteToWiFly("join ");
 WriteToWiFlyCR(m_network);
 delay(DEFAULT_TIME_TO_JOIN);
 bool ok = WaitUntilReceived("IP=");
 delay(DEFAULT_TIME_TO_WAIT);
 FlushRX();
 if(ok == false)
    m_printer->print("Failed to associate with '");
    m_printer->print(m_network);
    m_printer->println("'\n\rRetrying...");
    FlushRX();
    AutoConnect();
 else
    m_printer->println("Associated!");
    ExitCommandMode();
 // TODO save this configuration
 Enter command mode by sending: $$$
 Characters are passed until this exact sequence is seen. If any bytes are seen before these chars, or
 after these chars, in a 1 second window, command mode will not be entered and these bytes will be passed
 on to other side.
void WiFly::EnterCommandMode()
 FlushRX();
 delay(1000); // wait 1s as instructed above
 m_printer->println("Entering command mode.");
 WriteToWiFly("$$$");
 WaitUntilReceived("CMD");
 exit command mode
 send the "exit" command and await the confirmation result "EXIT"
void WiFly::ExitCommandMode()
 WriteToWiFlyCR("exit");
 WaitUntilReceived("EXIT");
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:RandomMatrix
