3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a 24V Power Supply from 2 ATX PSU
Two ATX PSU = One juiced DIY 24 Volt DC Power Supply
Before we get going, i have to make it clear that this is by no means the safest solution, and that might even be and under estimation. I am no expert, and copying my steps is at your own cost. If you are in doubt don't try it.
Introduction:
This is my first instrucable since i couldn't find this project anywhere i thought i might aswell document it with pictures.
Also English is my 2nd language so bear with me.
Well, what you get when done is a 24 Direct Current (DC) Power Supply (PSU).
Parts list:
2* XXXX W ATX power supply.
Pliers/knife
A good length of mains cable.
Scrap wood or what you think is suitable.
Common tools (screw driver/hammer, saw, nails/screws and so forth)
Soldering iron with accessories or alot of male/female connectors.
Nice to have list:
A clue gun.
Multimeter. I nice to test things out before frying electronics.
Common sens.
Everything was sourced for free except for tools. This made this a perfect fit for my needs.
P.s.
If i missed something please point it out, but if you have the above tools i have no doubt in my mind that you can make it.
Look all syncronyms and words up on wikipedia before asking.
Step 1Theory / Build
Theory / Build
Since there more and more computers laying around the junkyard theres more and more ATX PSU to get for free.
The higher the wattage  described on the PSU the more amperes it can pull when done.
Small PSU will be suitable for testbeds where bigger could be used to weld or power a CNC (as I'm doing).
Before going any further if you scavanged your PSU like I you should test them out before spending more time with them.
Short PIN 14 (on standard ATX PSU) to any ground wire. It will make the PSU turn on, test with a multimeter. For any iregular PSU search around for howto-short-a-PSU. For pictures (i forgot to document that step) just take alook around instrucables and you'll be able to see how to do that step. Theres different way of doing this, but they all do the same job.
There also alot of chatter about how you keep the woltage steady without spikes. Again see other instrucables since most PSU are different an all have different build in features.
I went with a KISS solution.
The two PSU is now called PSU A and PSU B
Since theres some capacitors, inside the cabinet, which can still have a charge in them, wait a while before working with the PSU if they have been powered recently.
Now tear apart both of them. You do this to clear any ground connection there might be, remember to remove the ground (GND) from the mains line you are powering the units with, then you are sure that part of the project don't go FUBAR on you. I would not reuse the metal cabinets, period. Theres way the much risk in them making a contact with any loose wires. Which could result in frying you/electronics.
We can then procced to connect the +12 V wire from PSU A to PSU B GND wire, that will give PSU B GND a +12 V DC as GND then you add the additional +12 V DC it produces on it's own when powered on. To utillize the +24V DC you've created between the PSU you need to use PSU A GND wire  and PSU B +12V DC wire in operation and between those to wire to be more excact theres +24V DC @ the amperes that one would have given.
I also slashed all wires i wouldn't use for this project to inhance airflow in the small cabinet i build. Again think twice cut once.
8 comments
May 23, 2012. 9:19 AMLectric Wizard says:
I did something similar,but instead of addig a vent to the front I turned one fan around so one sucks in & one blows out of the cabinet. Seems to work just fine. Cheers!
Feb 10, 2012. 6:36 PMOmnivoreNZ says:
This site has a similar idea, stacking 6 PSUs to get 30V at 40A. http://w5jgv.com/tower_of_power/index.htm  - but it looks much messier than the way you've done it. I hadn't thought of simply throwing away the metal cases which allows a much cleaner and better looking unit. Thanks!
Jan 19, 2012. 2:31 PMElectronics Man says:
Great Job! I need to make a 24 volt power supply for my CNC machine and this is the design I will probably use.
Nov 28, 2011. 10:26 AMicatchem925 says:
excellent Instructable. Needed a 24v PS for project, this worked perfectly. Easy build with no problems. Thanks.
Jun 7, 2011. 10:27 AMgullfunk says:
you can get 24v from one psu you use the -12v(blue) wire as ground and a +12v(yellow) wire as positive. and you get roughly 24v
May 27, 2011. 5:07 PMzack247 says:
this is great!
i have been unable to find any 24v adapters anywhere, thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Zilver
