Two Balancing Bats
Introduction: Two Balancing Bats
Taking a break from complicated assembly and balance, Two Balancing Bats (one smaller and one larger) is another, yet much simpler venture into the Autodesk Fusion 360 feature "Center of Mass" calculation.
This Instructable is quite simple; print either or both bats at 100% infill, and the cone at 20% infill. Place the indent located at the bottom of either bat on tip of the cone, and give it a spin. It is very important to print the bats at 100% infill in order to maintain the correct center of mass (at anything less than 100% infill, your slicer infill pattern, as well as mine, is more than likely not balanced). The bats should balance on just about any small pointed object; a pencil, pen, or as shown in the video a round file in the tower mount of a prototype Octopus from "SS OhNo" (
I've included all files, this time including the Autodesk Fusion 360 file "Two Balancing Bats.f3d"that will enable you to load into Autodesk Fusion 360 in order to examine, modify and/or improve the design steps I executed in the design of Two Balancing Bats. While I'm still learning Autodesk Fusion 360, I truly welcome any and all input into the design process of Two Balancing Bats in order to improve upon my efforts at this and future designs.
As usual, I probably forgot a file or two or who knows what else, so if you have any questions, please do not hesitate to ask as I do make mistakes in plenty.
Designed using Autodesk Fusion 360, sliced using Cura 2.5, and printed in PLA on an Ultimaker 2+ Extended and an Ultimaker 3 Extended.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    nice! I just viewed your ss ohno project. I love it!
    Thank you very much, I'm glad you liked them!
