Two Dollar Rocket Motor
This instructable has been removed by the author.
126 comments
1-50 of 126next »
Sep 29, 2009. 9:00 PMshastalore says:
Dude! I beg you to delete this instructable. I searched the term "rocket motor" on Instructables, just to see what clever motors others have devised and safely tested. But what you've described is no more than a crude pipe bomb. It's not truly experimental, since it will never produce useful, predictable thrust, and someone could get killed, or incur grievous injury if they attempt to duplicate your process. The copper tube can easily become deadly shrapnel if the propellant burns too fast -or is allowed too little nozzle to escape through. Really. Your other two instructables are quite interesting and imaginative. Delete this instructable and you'll be batting a 1,000.
Sep 20, 2009. 6:51 PMChr1spy says:
this is dangerous u should use paper tubes if paper tubes explode they are not as dangerous because they don't shoot dangerous shrapnel seriously us paper tubes
Sep 7, 2009. 11:09 PMDenger says:
It is my belief that that there is a very high probability for serious bodily injury using your construction and ignition methods. Why use a metallic copper casing when a wrapped paper cylinder or ceramic casing would work just as well, without the possibility of dangerous shrapnel in the case of explosion? Why use cannon fuse instead of an inexpensive electric igniter? The ignition sequence of an electric system may be safely aborted at any time prior to ignition, and the cost cannot be much more than for specialty cannon fuse. A $2 rocket 'motor' suddenly becomes a whole lot more expensive with the bill from an emergency room visit tacked on to it.
May 20, 2009. 2:05 AMTombini says:
What a nice name for a pipe bomb; "rocket"
Jun 15, 2009. 4:00 PMdagenius says:
Not exactly a bomb... will actually produce substantial thrust for a small model rocket.
Jun 15, 2009. 8:31 PMTombini says:
Its made of copper with an inadequate nozzle pressed together with pliers, no though for safety has gone into the design and it is just a pipe bomb waiting to happen! Ive been working with high powered rockets for 4 years and that thing will encounter problems.
Jul 5, 2009. 11:53 PM-Cry_Wolf says:
Oh?
Jul 7, 2009. 12:34 AMTombini says:
"Oh?"?
Aug 18, 2009. 10:18 PM-Cry_Wolf says:
Ya :-D
Aug 20, 2009. 4:43 AMTombini says:
Rawr
Aug 9, 2009. 7:35 PMprofessorPyro says:
how stable is the propellant? does it store?
Aug 31, 2008. 9:38 PMwhyheneeds says:
the last comment is totally correct it is dangerous ,if the explosion is powerful enough all you will be making is a "pipe bomb" that could very easily kill someone!!!
Jul 24, 2009. 11:44 AMcowgomoo says:
no its a rocket motor till it has another cap and the folded part would come up copper is very mailable especially when hot. dont be stupid a pipebomb is completely different
Jul 7, 2009. 3:38 PMdagenius says:
You don't have to say "the last comment...," you could just click the reply button on that comment...
May 5, 2009. 7:01 AMDealmann says:
gd idea, just watch out to make the hole big enough or it will explode
Jul 7, 2009. 3:37 PMdagenius says:
if you weld the nozzle shut, an ignition in general is unlikely... oooohhhh, what!
Nov 21, 2008. 11:31 PM270168 says:
I live in Surrey BC Canada do you know what store I can get potassium nitrate at? (it shouldn't be too far away from the peace arch crossing or the pacific crossing)
Feb 27, 2009. 7:23 AMwarrant says:
I HAVE BEEN A PYRO-TECH FOR MANY YEARS. YOU CAN GET KNO3 JUST@ ANY RX SHOP ALL YOU HAVE TO DO IS PLACE AN ORDER FOR POTASSIUM NITRATE , YOU CAN GET THIS AT ANY WAL-MART PHARMACY OR GO TO YOUR LOCAL FEED CO-OP AS THIS IS SOMETIMES USED IN SMALL PORTIONS IN ANIMAL FEED
Jul 5, 2009. 11:54 PM-Cry_Wolf says:
Dang, you might just use more caps than Billy mays.... aww.. now I made myself sad :-(
Jun 15, 2009. 4:01 PMdagenius says:
use caps sparringly, mate...
Apr 4, 2009. 11:22 AMgreasypirate says:
SORRY WHAT DID YOU SAY?
Jun 16, 2009. 8:23 PMgrizzly g says:
what is the srew for? jw
Dec 14, 2007. 5:12 PMdeathsithz says:
bombs impload this will not if you make the nossle right that means DON'T BLOCK THE NOSSLE (now some stupid is gonna kill him self doing just that)
Jun 15, 2009. 8:45 PMTombini says:
Bombs EXplode not IMplode, (unless your talking about a nuke)
Aug 20, 2008. 10:50 AMthatoneguy900 says:
In pyrotechnics, putting compositions into metal containers is generally VERY BAD. Stick with Paper tubes and clay plugs/endcaps. You can make very strong tubes with a dowel, some manila folders, and wood glue. The ones I make can't be crushed with your fingers, and make perfect rocket engines, that won't fll you full of shrapnel if the device explodes.
Jun 15, 2009. 8:33 PMTombini says:
Although copper is malleable and conductive you shouldn't say it will decrease shrapnel, (not noticeably anyway). As a general rule ALL metals produce shrapnel, just look at lead it is soft and malleable and makes good shrapnel...
Feb 18, 2009. 2:09 AM831 says:
in sted of useing coper pipe u can use cut upe cans cus the metal is much more lihter an u can rapit in lots of war like cardborde ferst then then seler tape an the the metal of a cocacola can then a bit i duck tape to mack it tiyt
Jul 7, 2009. 3:36 PMdagenius says:
If you use proper spelling and grammer, people will take you more seriously. I could understand most of what you said, but whats with the: rapit, seler tape, mack it, tiyt? Really, 831, not cool.
Feb 18, 2009. 1:57 AM831 says:
ha I'm new an I love all wet I see A dent A put a video o g off it bein propeld out of sum pipe or scafholdin pols that wuld mack it fly fare have A tested it out
Nov 25, 2008. 3:03 PMortho says:
looks like a good way to blow your fingers off
May 12, 2009. 1:40 AMAussieJake44 says:
you should try it and type up the results. if you can.
Jul 16, 2008. 5:49 AMTombini says:
I have made an instructable explaining a more powerful way to make the rocket candy...<br/><a href="http://www.instructables.com/id/How-to-make-rocket-candy/">http://www.instructables.com/id/How-to-make-rocket-candy/</a><br/>Please leave comments<br/>
Jul 13, 2008. 12:42 PMtwenglish1 says:
you know your rocket fuel is the is made the same way as homemade smokebombs
Dec 13, 2007. 11:28 PMDungeonbrownies says:
I dont think this is an engine, im pretty sure this is a pipebomb. you know if anyone sees this then you'd be questioned and maybe arrested on terror suspicions you know...
Jul 2, 2008. 2:57 AMspyder1313 says:
What makes this different from a bomb, is that it has a semi-restricted exhaust portal.
Dec 14, 2007. 12:23 PMaltaria1993 says:
no, a bomb will not have a nozzle, this does, so its not a bomb, this is the wiki page about it *quote* "a tightly sealed section of pipe filled with an explosive material."*unquote* this is not tightly sealed.
Dec 14, 2007. 4:06 PMkruser495 says:
a bomb has a hole for the fuse/ same thing
Dec 16, 2007. 12:56 AMaltaria1993 says:
in a rocket, there is still space left for the gasses to get out, in a bomb not, otherwise it wouldn't explode at all :X
Jan 7, 2008. 3:09 PMaviationant says:
if thats true then why would nitrocellulose?
Jan 9, 2008. 7:00 AMaltaria1993 says:
because it has such a high burning rate, the gasses cant escape fast enough, and it will explode if you use a too weak shell, after it flew.. a bit
Jun 15, 2009. 8:37 PMTombini says:
Nitrocellulose doesn't have a high "burning" rate, if under enough force it detonates
Dec 14, 2007. 3:13 PMDungeonbrownies says:
Ah, you have a point.
Jun 25, 2008. 5:54 AMgizmomanish007 says:
dude dose it rotate like DC MOTORS
Dec 14, 2007. 4:43 AMflamerz14 says:
I wonder if nitrocellulose would be as effective and safer?
Dec 16, 2007. 1:00 AMaltaria1993 says:
do you actualy know what nitrocellulose is?
its one of the most explosive chemicals this is what it is
nitrocellulose safer?!? where the hell do you have your brains?!? if this goes wrong, its just a firecracker that shoots copper shrapnell, otherwise your dead, just dead..
1-50 of 126next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:navaburo
I am a student and hobbiest. I'm into physics, linguistics, sailing, electronics, hacking (not cracking), music, and the like. I post most of my project stuff on my blog: http://hotwigati.wordpress...
more »
