3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Two-Liter Shelves
Two-Liter Shelves
These shelves are made from shipping flats for two-liter bottles of soda and some MDF. Were I to do them over, I would recommend replacing the MDF with 3/4" plywood for strength and resistance to splitting. Hopefully, the flats and the wood can be found for free with a little determined scavenging.
These shelves fall precisely into the "nomadic" furniture tradition proudly pursued by fellow Instructable-ers. Since the flats have handles on them already, and a nice rim around the edges, the idea is that the shelves can break apart and be used as containers for your books while moving.
This is a really simple project that can be done with a screw gun and a hand saw if really necessary, but a bandsaw or jigsaw will really speed things up.
Step 1Structure
Structure
The first drawing shows the pieces of wood that need to be cut, as well as the cuts that need to be made in the flat itself. Basically, on opposite corners of a board, I made notches and projections so they would fit together later. The dimensions are listed, and the drawings are to scale. However, the strict dimensions are not important -- your materials and circumstances may be different, so size to fit anyway you want.
The base of the shelves is one flat that has had the handles trimmed off flush with the rim so that it would lie evenly on the floor. Then, two 3-1/2" by 3/4" notches were cut in the bottom of the flat, one on each side, shown as the grey patches in the first drawing. A Dremel with a metal cut-off wheel or RotoZip works great for cutting the plastic. To take the burrs off, run a scrap of 100 grit sandpaper over the cut edges.
Cut your wood as shown to whatever height you want the shelves to be spaced apart. Fit the narrow projection of one of the pieces of wood into the notch, and screw through the side of the flat to secure it. I used cheap drywall screws. Pre-drill holes, especially if you are using MDF, to prevent splitting. Repeat on opposite side.
Cut into another flat the same way, and align it above the first, so that the notches are above one another. Screw in place. That makes a complete base unit. For the stackable, modular shelves, sucessive pieces only have one flat and two piece of wood. See the second drawing for how they are supposed to fit together.
An eighth or quarter-inch diameter threaded rod spaces and braces the back.
5 comments
Jul 23, 2009. 6:08 PMAzureEyes says:
what is MDF?
Apr 8, 2009. 8:01 AMJZ Price says:
it looks like those red holders are nto for teh 2 liters. the ones that you have are for the 4 packs of 6 bottles of XX oz.
Jul 21, 2008. 9:46 PMmycroftxxx says:
Allright, I like this project. I gave it 3.5 stars, but I would happily bump to 5 if some extra instructions showing each step in the cutting process were added. (I know that you are done with this project, but having an image of the un-attached side panels would be really helpful) Very nice work!
Jul 21, 2008. 11:23 AMcanida says:
This looks like a nice improvement on the classic milk crate shelving option. ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
428
Author:wholman
I am an artist, writer, and designer who graduated with a degree in architecture in 2007.
