3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Mold Making: Two Part Silicone Mold
*UPDATE* I'm going to include some FAQ's to answer some of the questions I've received. { FAQ }
This tutorial will demonstrate how to reliably reproduce cast objects using a two part silicone mold. This technique, when skillfully applied, can have incredible resolution, effectively cast very complex shapes, and can yield parts that need little cleanup. This type of mold is most useful for parts that are fairly small, and therefore will not consume a massive amount of silicone to cast. To save material on large castings, techniques such as glove molding and matrix molding are often applied.
Step 1Select, clean, and add sprue
I chose a figurine from a comic shop as my demo to mold. This will be what is called the master. It has a fair amount of surface detail, and some small parts that, although tricky, are faithfully reproduced in the final casting.
Begin by inspecting, cleaning, and securing your model. I glued down the small parts that my figurine came with which originally snapped together. I took a cotton swab and got out all the grit and dust from every tiny crevice. Remember that everything you see on your part will be cast into the mold, even down to fingerprints. You will not be able to correct these mistakes once the part is cast, so take the time to do it right.
You will need to create a sprue or sprues on your part. These will become funnel shaped holes in the mold. You need them so you can get your casting material into the mold so don't forget to put them in. I usually use the tops to bottles or machine my own, but you can make most any tube or funnel shaped object work. If you'd like, you can even make your sprue out of clay. I usually smooth the seam in between the sprue and the master as to not catch bubbles on the very bottom of the part. Try to think ahead when you're molding a part, if something looks like it will trap bubbles, try to orient things to avoid it. Your goal is to create a mold that will produce the best quality parts with the least amount of work and fiddling.
77 comments
1-40 of 77next »
Jul 21, 2008. 12:56 PMramses says:
I only wish you could cast aluminum in it...
Oct 26, 2008. 9:31 PMfrollard says:
You can cast many low-melt alloys into silicone - it can withstand many hundred degrees celcius; it can do pewter, or lead no problem. Not sure about aluminium.
Mar 19, 2009. 1:52 PM_soapy_ says:
Seriously watch out for moisture and water if casting aluminium. Ensure the mould is totally dry, and above 100 C, before a steam explosion ruins your day. Silicone won't take that heat from liquid aluminium, though.
Mar 19, 2009. 2:24 PMfrollard says:
Silicone should work with low-melt alloys; tin, lead, pewter...not sure about aluminium... it can handle temps uip to 588Kelvin (600F) aluminium melts at ~933Kelvin - definitely not a good plan. Good thought on the steam/water. Dry the mold, and pour slowly :D
Mar 30, 2012. 10:11 PMszrlcassi says:
Do u have a good supplier of silicon rubber? If u want more contacts, maybe u can consider us.
our web is www.szrl.net or you can search our company name Shenzhen Hong Ye Jie Technology Co.,LTD.
My email address is hyjg@szrl.net. Pls contact Cassi
Mar 31, 2012. 8:10 PMfrollard says:
Stop posting spam. Seriously. The reason the last account was banned was because you are not welcome here. Eff off.
Mar 26, 2012. 1:37 AMsimonzhou says:
Hi frollard,we are biggiest manufaturer in China and we can teach you how to make a mold and provide you free samples for testing.Pls contact me 0086 13790224736 or MSN:simonzhou520@hotmail.com
Mar 21, 2009. 5:24 AMdeathpanda says:
you could however take this mold pour melted wax in to it and make a wax master for lost wax casting. all you would have to do is add vents and set it in casting sand
Mar 21, 2009. 7:01 PMfrollard says:
Indeed - just wouldn't work for single-step processing. Damn I hate living in an apartment - i want so much to do so many...garage-y things.
Apr 2, 2009. 8:28 AMHelos says:
I agree with you completely. I didn't realize until I moved into my own place just how necessary a yard and garage are. I also totally miss having a BBQ... Oh well, just plans for the future!
Mar 22, 2009. 11:22 AMdeathpanda says:
yea im kinda in the same position. i just made a vent hood and workbench in my place. not the safest idea but it works. i do small castings in the house.
Sep 6, 2008. 4:50 PMcasey321b says:
that would be sweet
Mar 30, 2012. 10:09 PMszrlcassi says:
Dear Manager,
This is Cassi from Shenzhen Hong Ye Jie Technology Co.,LTD, a leading manufacture of RTV-2 silicon rubber in China, our web is www.szrl.net
Our products are similar with Dow Corning, Smooth-On and other reputed brands in the world.
If u want contact me for details, pls send email to hyjg@szrl.net or call me at 8615220073603. Tks very much.
Feb 19, 2009. 11:42 AMRufo says:
I have just made a rather complex mold of a sculpture I made in clay, the shell I made with plaster and it looked great, till I opened it and notice that the silicone was taky and stiky at some places... maybe the mixing went wrong is there something I can do, I can't afford to loose this mold... thanks
Dec 1, 2009. 6:15 PMEmphantasy says:
 It also depends on what type of RTV silicone you used, tin or platinum.  Yes, products containing sulfur will inhibit platinum-based RTV, but I've yet to have that problem with tin, which cures against most anything.
Mar 26, 2012. 1:10 AMsimonzhou says:
Hi dear friend,
Are you using RTV silicone for mold making?
We are biggest manufacturer of silicone rubber,we can provide you good quality with more cheap price and free samples for testing.
Pls reply me at : simonzhou520@hotmail.com
Thanks
Simon
Mar 26, 2012. 1:11 AMsimonzhou says:
Hi dear friend,
Thanks
Simon
Feb 3, 2011. 6:57 PMscottouradnik says:
I'm looking to make soap molds and need a good supplier for the silicone, any suggestions?
Mar 26, 2012. 1:02 AMsimonzhou says:
Hi dear scottouradnik,
I know some good supplier who can provide good qulity with cheap price,hope can help you.Pls contact me MSN:simonzhou520@hotmail.com
Jul 4, 2011. 8:00 AMjoannashi says:
hello, we are a professional manufacturer silicone rubber, contact me at my email hyjb@szrl.net. we can provide you most competitive silicone rubber to make molds for soap.
Mar 2, 2011. 6:29 AMbluebel95 says:
Can I use it to make cakes or gummy candies? :)
Sep 12, 2011. 4:52 PMspiderham says:
Corn starch is used for gummies. Just spread the powder into a tray, press your master into the it and pour slowly into each cast. This is the method used at a candy shop I worked at some time ago. Once set, dump the whole thing over a screen and reuse the powder.
Mar 2, 2012. 2:24 PMtinker234 says:
wow thanks
Jan 1, 2012. 5:22 PMSheilauva says:
I am using window silicone, clear, sealant for my two part molds. I have not done this in 15 years and have forgotten what to use for a release, not for the clay, but for the seams around the clay. The silicone will stick to itself, so what do you use for the second half of the mold. Does this make sense?
Can I use canola spray on the silicone to release or vaseline, or do I have to buy a can of silicone release?
Jun 8, 2011. 11:53 AMTraeh says:
This is EXACTLY what I was looking for some small sculptures I wanted to cast in resin! Thank you for this awesome ible!!!
Jun 23, 2010. 11:39 AMg0nn el tren says:
how can i mold this: http://www.flickr.com/photos/14455307@N07/3804998669/in/set-72157618890095073/ i want it empty from inside
Nov 24, 2008. 7:12 PMn0ukf says:
Do you know of any casting materials that cure near crystal clear (like for lenses, etc)?
Dec 1, 2009. 6:18 PMEmphantasy says:
 I've used a lot of water clear urethanes from various companies- what they all have in common is that you'll need to use platinum-based RTV.  Tin based silicone has trace amounts of alcohol in it, which soft durometer urethanes/clears don't get along with.  Of course, you can also heat a tin mold or let it age naturally to get rid of the alcohol, but that takes time.
Apr 7, 2010. 1:51 PMstageright2 says:
How long is the aging process and what temp. and length would would you need to bake it for. thanks ASAP
Apr 7, 2010. 3:18 PMEmphantasy says:
It depends a lot on the thickness of the mold...the thicker it is, the longer it takes to bake out the alcohol.  If the mold is 1/2 in thick, I'd guesstimate 90 degree F. for about 2 days.  I wouldn't go over 100 degrees F, because increasing the temp, while perhaps shortening the time needed, might also damage your mold.  Of course, this is done with the silicone fully cured, the master removed, and the mold laid out in the oven opened up, if possible.  Let the mold cool to room temp. before casting the urethane, and do a test shot if possible on the outside of the mold to check if the alcohol is gone before trying it in the cavity.  If the test shot is still tacky, bake some more.
Mar 23, 2010. 11:30 AMsocalcovey says:
Hi, I was wondering if you could point out the sprues in this picture. Im new at this and I want to follow your recipe to the T. Thank you.
Feb 5, 2010. 7:38 PMjames oakley says:
I am looking for a business partner to help design and patent a idea I have.  Setting up a mold design is key.  This product also uses recycled plastic and wood.  I have done some research on my idea and no one has come up with this idea as of  yet.
This would be a great product to sale on HSN or QVC.  This product would repeat it's sales yearly.  Indefinitely!
If interested, contact me (James) oakleyrest@yahoo.com
Feb 12, 2009. 11:02 AMamoceuazul says:
(removed by author or community request)
 Vacuum casting could also help- do you have enough gates/vents?
Mar 19, 2009. 1:47 PM_soapy_ says:
What mould material are you pouring the wax in to? If it is too cold, like a metal mould would be, the wax will chill and stick on contact. You might need to warm the mould up, pour the cast, then let the whole thing cool. Also, you should have an obvious path for the air to vent upwards from all the high points that will trap air, and you should pour down one sprue until you see the material at the other sprue(s) - if this isn't happening, something is blocking them. If they are too narrow, then the wax will set as it cools onto the mould, and that could well be your problem.
Aug 23, 2009. 5:32 PMbanditsrubyangel says:
I have a pair of detailed flexible plastic wings that are curved. The wingspan is about 8 inches. Would this method work for them?
Dec 1, 2009. 6:12 PMEmphantasy says:
 Hi.  If your master is really detailed, you might want to think about vacuum casting it- this process helps a lot with fine details.
Aug 24, 2009. 1:04 AMannie33 says:
hello,this is Annie,you can contact with me more information about silicone rubber for making molds,annie7301011@live.cn.
1-40 of 77next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
111
Author:bofthem(HAR.MS)
I'm M@. If you know Prototype This, TechShop, The Best of Instructables, Show Me How, or AVPII: Requiem, you've seen some of my work and the cool stuff I've been involved in. I build and design and ma...
more »
