It uses a method of construction first posted here: http://www.instructables.com/id/Scrap-Table/. That table uses a random assortment of scrap wood, which is certainly an option in this project as well; I opted to present the different material in a more organized way this time.
The materials can vary in cost, depending on how much you salvage and how much you buy new. I had a mixture of new 2" x 8"s (which I judged to be most cost-efficient dimension based on how many 1-1/14" strips I could get out of each board) and scrap 2" x 4"s and scrap cedar. Along with the threaded rods, sanding belts, polyurethane, new drill bits, screws, etc., the table cost about $50 and about 30 hours of time.
Thanks to Ramell Ross for the first five pictures. http://www.ramellross.com
You will need these materials:
Cardboard for template
4-6 2" x 8" x 8' yellow pine or equivalent
1 2" x 4" x 8' contrasting wood
1/2" x 24" pine dowel
7 1/2" dia. x 36" threaded rods
14 nuts and washers
2 lbs 2-1/2" drywall screws
wood glue
60, 80 or 100, 120 grit sanding belts
polyurethane or varnish
rags
You will need these tools:
Table saw
Chop saw
Drill
Impact driver (optional but very helpful)
Hammer or mallet
Ratchet set
Dremel or hacksaw
Belt sander
Clamps
Ratchet straps
Orbital sander (optional)
Remove these ads by
Signing UpStep 1Templatin'
This table is about 48" long at the shelf, 24" wide, and 17" tall. The legs cant outwards at about a 20o angle. The profile is a uniform 1-1/2" thick.
Fit your table to your space; it would look a little more graceful if it were longer than I made it.
When built and finished carefully with hardwood; this one project could net you 3 to 4 hundred dollars. Not bad for an afternoon's work. You have a nice shop or at least access to a nice shop and I'd really encourage you to continue to elevate your skills to a level that your designs deserve.
Keep on keeping on.
One the third pic, the left 'leg' looks vertical, rather than slanted. Just an optical illusion?
I think the grain would be beautiful as furniture as well, just need more help with details and tips like yours are what make me love this site nearly as much as I love dreaming about having all the time and energy to try every project on here. It's like a giant think tank for the handy and geeky all rolled into one. And I mean that in the best way, as I take quite a large amount of pride in the geekiness of my nature.
They are tongue and groove and unfinished as well. It makes for a gorgeous floor but a mess of a residue even years after all the sanding has long been completed. I still find sawdust on screens I forgot to wipe down after all was said and done. I will, indeed, need luck.
only one question: how is the torsional rigidity of the table? (not saying it's not good, i'm genuinely curious) obviously the lower shelf pieces help a lot with that.
Good job.
