Step 11Troubleshoot until there is no tomorrow.
No matter if you've done everything right up until now, chances are you will probably have something go wrong.
If absolutely nothing happens, your keyboard is probably dead. Make certain of this and then go hack another one.
If one key is being typed into the window over and over and over, then one of the buttons is being pressed down by the striker bar. See if it stops when you slide the button out from under that key's striker bar. If it stops, all that means is that you have to reposition your bracket so that the key isn't being pushed down. Pry it lose and break off the epoxy. Reposition and re-glue the bracket.
If it does not stop hitting the key over and over, start to cry. There is something very wrong with your wiring and/or many keys are being repeatedly struck at once and confusing the keyboard. Determine which it is and then act accordingly.
If nothing happens until you press a key down, then you are doing well. See if you can get every key you press to show up on the screen. This may take some repeated calibration.
Add Comment
