3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Typewriter Computer Keyboard
Step 3Pop out the metal bars.
With the On/Off switch removed, the next step would be to remove the bar that locks the keys in place as well as that other redundant metal bar. This is a bit trickier.
The other redundant metal bar can be easily pried out. Do that.
Now locate the metal bar that locks the keys in place. Remove the spring wrapped around the middle of this bar. You can try pulling it off with your pliers. If that does not work, try snipping it with your clippers. If both of those methods are giving you trouble, you can always saw it in half. Once the bar no longer has the spring action, removing it should be a tad bit easier.
The next thing that needs to be done is to saw off the little round tab that helps keep the bar pivoting along its path. This is a small steel bar and hard to remove short of sawing it off. If you are looking at your keyboard with the key-side closest to you, it should be on the right.
Once the small metal guide bar is removed, the next step is to forcibly remove the key-stop. Simply, close your eyes and pry it out with a screwdriver. You are closing your eyes on the slim chance it pops out and hits you in the face.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2364
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
