Step 6Glue the brackets into the typewriter.
Essentially the brackets are glued to the inside of the case, upside down (because don't forget the typewriter is still upside down). There should be one glued to each side of that big bolt (see picture).
Now here is the tricky part. The brackets need to be glued in a manner so that when the typewriter is flipped back right-side-up, the buttons will be as close to the striker bars as possible without being pushed down.
Again, this may seem easy enough, but remember that the weight of the buttons will make the bars sag towards the middle, which means when you glue in the brackets you should overcompensate with the placement a tiny bit on each side. If you don't overcompensate, the keys in the buttons in the middle won't be hit by the striking bar.
But wait! If you overcompensate too much, the buttons on the end may get pushed down without being hit. Again a major problem.
So, in short, be very careful placing the brackets just right.
Which brings me to the next big reason this step is so annoying: the epoxy takes about 20 hours to fully set. Thus, the length of this project is dependent on how many tries this step takes. Every time you have to redo this step, the project will take one day longer to complete. Still, don't be disheartened if you wait an entire day for it to dry only to learn that you have to break out your chisel and glue it again.
With that said, you also have to figure out a way to firmly hold the brackets in place for the 20 or so hours for the epoxy to reach full strength. This can be tricky in and out of itself. I used a thin piece of tape wrapped tightly all the way around the side of the case.
Add Comment
