The principle of this design is a tyre is used as the bladder and this is moved up and down via a crank (hand driven in my case with the option to be driven by motor). Air is directed through the tire using simple one way valves, as the tire is raised and expanded mechanicly air is drawn thru the one way valves (intake side),into the tyre.
Then as the crank forces the tyre to a squashed postion the air is forced through the bottom one-way valve and to your piping.
Uses for this project could include: air for a foundry, aerating water, filling balloons, pumping water ect.
With this re- use of a tyre, you could scale it both ways and get great results, e.g. a small model aeroplane tyre hooked up to a 12v motor would be a great fish tank oxygenator or a larger truck tyre version could keep an aquaculture company aerated.
Those willing to change the valves around could also pump water.
Also if you are going to put this into long term use I recommend using proper bushing and bearing techniques, as I have not designed this one to be used for long.
Remove these ads by
Signing UpStep 1Things you need
Tyre and inner tube, Wheel barrow wheel in my model.
bolts out of your own collection or local shop,
suitable hose connector, to suit your piping
3mm (1/8th) steel plate,
Washers,
40mm x 3mm steel flat bar approx 1 meter ,
Steel tube 75mm x 38mm approx 2.5 meters ,
rivets and washers to suit,
silicon sealant,
70mm I.D pipe (50mm long)
PARTS YOU WILL MAKE
Base, Five anchor pionts, At least three valves, Rocker arm, Crank (optional motor drive), Air chamber, Two tyre anchor plates.
TOOLS
Welder / or tech screws if you want to do it differently,
drill,
file,
cardbaord,
grinder,
spanners,
20mm reduced shank drill
12mm drill
Clamp
12
comments
Add Comment
rimar2000
says:
robbtoberfest
says:
Add Comment
