3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Tyvek Bivy Sack for Camping/Hiking
A Bivy, or Bivouac Sack is a bag for your sleeping bag. In good weather, they keep your sleeping bag clean, in bad weather, they keep you dry (mostly)... Bivys are basically a waterproof shell that protects your sleeping bag. They have an added benefit of keeping dew off your sleeping bag, and slightly increasing your warmth. The only down-side is that the bag will trap moisture (perspiration) in the bag. In hot/humid conditions, this can be a big problem.
In this Instructable, I'll show you how to make a cheap bivy that works well in decent weather and is not terribly heavy. In rainy conditions, you should have additional shelter over you. (Commercial Bivys start around $80.)
This bivy is constructed from 14'-15' of 3' wide Tyvek House Wrap, and double-sided carpet tape. The basic design is a full length of tyvek folded at the foot and sealed on the sides.
One important note: This bivy does not breathe. Never seal up an unvented bivy over your head!
Step 1Materials/Tools
Materials/Tools
Required Materials:
Approximately 15' of 3 foot-wide Dupont Tyvek Home Wrap (or similar).
Double-Sided Carpet Tape (the permanent kind)
Velcro
Tyvek Tape (optional)
Tools:
Scissors
Measuring Tape
Wallpaper seam roller (Optional)
washing machine
Build Time: Approximately 2 hours, with a break for drying the tyvek...
10 comments
Feb 16, 2011. 2:46 PMmimulus3 says:
According to the dupont website, tyvek is water repellent (when the tyvek wording is facing out) and allows moisure/water vapor to pass to the outside from the inside. In other words, it "breathes", not las well as cotton would, but is more permeable than cling wrap or plastic. So putting this together with the words facing inside defeats the purpose.
Also, I think it is infinitely easier to cut out your pieces, wring the tyvek instead of crumpling it, then unwring, crumble into a ball and then wash. My front loading machine had no problem with this, as you do not have a "bag" yet and the water spins away.
Then you proceed as usual. I used duct tape and did not bother turning inside out to have neater seams. I am a long time fabric seamstress and it is standard practice to preshrink/pretreat your fabric before assembly. and it worked great here too.
Just hoping to add a few refinements to this great tutorial.
Oct 10, 2010. 4:27 PMejacques says:
I'm not sure but you seem to be using it with the Tyvek printing on the inside.
You should try it with the printing on the outside. Tyvek is made to "breathe" in one direction. It's basically waterproof on the printed side and the back is supposed to allow water molecules to flow through.
Great idea and since I have half a roll sitting outside and am going camping in two days, I now have a project for tomorrow!
Thanks!
Oct 15, 2010. 2:37 AMejacques says:
Actually, it seems that I was wrong...
I did some research on Dupont's web site and haven't found any mention of it being able to "breathe" only in one direction. There is also no mention in the technical documentation of needing to install it with a specific side facing outwards.
Hmm, I guess we were simply told this so that the printing would be visible.
I didn't actually try it. I was going camping with someone who had never gone before and he felt more comfortable with us using a tent. But I'll definitely try it.
Thanks again!
Aug 9, 2009. 12:44 PMhpstoutharrow says:
Great choice of material Seems perfect for this application! Question: Does the Tyvek lose any of its weatherproof ability when it is softened by wrinkling and washing?
Oct 8, 2010. 9:40 AMTrailH4x says:
Nice! I've got a small sheet I have used as a ground cloth under a tarp, but never thought of builidng a bivy out of it! Great concept!
Aug 1, 2009. 4:58 PMDELETED_GuardianFox says:
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:jsawyer
