I have measured its frequency here: http://www.instructables.com/id/Frequency-measurement-by-Lecher-Line/
Remove these ads by
Signing UpStep 1Three - dee assembly
The frequency of the oscillator depends upon a tuned circuit - a parallel connection of an inductor and a capacitor. I shall not use a separate capacitor, depending on the capacitance of the wiring and the internal capacitance of the transistor for this function. The inductor shall be made pluggable, so that I can use successively smaller inductors until the circuit stops oscillating. The smallest inductor which still allows the circuit to work should produce the highest frequency.
For supporting the inductor, I am using a small scrap of board soldered at right angles to a larger piece, and supported by struts of connector pins soldered in. The sockets shall be pins extracted from an IC socket. The components shall be placed close together to minimise inductance so that the highest frequency may be attained.
It all starts with a circuit diagram - I have alloted about two thirds of the supply voltage as Vce and around 5 ma of collector current with a supply voltage of 12V.
M/s Freescale just provided the post-it note I used to draw this circuit. They do not endorse or recommend this circuit in any way.
I finally managed to get a UHF diode and when I moved the diode/probe loop close to the inductor as you do in your video, I get see no voltage on the analog meter. However, if I touch the bare wire of the diode loop to the inductor then I do see a very small voltage, around 0.1V or less, on the 1V scale. I tried with my more sensitive DMM on the mV scale and see the same sort of results.
In the meantime, I've managed to make another oscillator using a Mini-circuits POS400+ UHF chip that works just fine:
http://rimstar.org/equip/oscillator_mcpos400plus.htm
It would still be fun to get yours working though.
Thanks for your help and your great instructables.
