3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
UV Nightlight / Bulletin Board
This simple and practical ultraviolet (UV) nightlight project will illuminate your home with a beautiful soft blue/green glow at night. It is also bright enough to use as a small message board during the day to remind you of those important appointments.
You can write or draw on it using a standard yellow highlighter which glows a green color. I bought a pack of various color highlighters only to find out that yellow was the only color that would glow under UV. You may want to try your luck and see if you can find any other markers that work. If you do, please post a comment and share it with the rest of us.
S A F E T Y . N O T E :
The term "Ultraviolet", is misleading when used to describe LEDs. UV LEDs actually emit "near ultraviolet" light (400nm). This narrow wavelength falls within the same, much broader, band as regular fluorescent black lights. This means that UV LEDs are completely safe and will NOT damage your eyes or give you skin cancer - no matter what you have heard or read elsewhere on the internet.
Step 1PARTS LIST
PARTS LIST
You may already have some of these parts in your junk box. If you do then your project cost will decrease.
(1) 5VDC/300mA Unregulated Power Supply (Wall Wart)
PWR1258 @ $1.49 each from BG Micro
(1) 2.1mm 2.1mm Barrel Connector Plug
#PWR1255 @ $.06 each from BG Micro
(1) 2.1mm Panel Mount Power Jack
#PWR1145 @ $.99 each from BG Micro
(2) Ultraviolet (UV) LEDs
#LED1078 @ $1.49 each from BG Micro
(1) 3mm Sintra Expanded PVC Sheet (8" X 12")
$3.25 each from Solarbotics
(1) Piece of Plexiglas (mine is about 80mm X 100mm)
Available at your local building supply
(2) 150 ohm 1/4 watt resistors
If you need to purchase these items then I can recommend these sources:
BG Micro
web site
I am only a hobbyist and I don't spend a lot of money on projects, but the people at BG Micro have always treated me like I was their most important corporate customer. That kind of service is nearly impossible to find these days. Add that to their great selection and low prices and you have a winning combination.
Solarbotics
web site
Solarbotics is a great company with great products, but they are located in Canada. Because of this, you will need to allow a couple of extra days for shipping. You might be able to find a US source for small pieces of Sintra (less than several square feet in size) but I could not. If you do find a US source, please share it with us by posting a comment.
57 comments
1-40 of 57next »
Nov 19, 2011. 5:29 PMUATradition says:
Here's what I came up with just in case you'd like to see your idea being used : I gutted an old X-Box 360 SMPS I had laying around to use as the base/stand. I used 3 U.V. L.E.D.'s just to be sure I would get the desired effect. I also used a simple power plug I installed on the back side of the base and a 5.2vDC 320mA supply. And the best markers I found were Expo NEON Dry Erase Markers. Here are a few photos of my finished product :
Nov 19, 2011. 5:32 PMUATradition says:
I forgot to add the pics ! Here they are :
Nov 21, 2011. 10:45 AMUATradition says:
And there actually is a slot for the glass .... It sits down in there right on the top of the L.E.D.'s. ... It's only about 3mm in however and I used 2 part epoxy glue to stabilize it. I had to cut little metal plates to hold the L.E.D.'s. And hopefully I'll learn quickly ... I have been in fact. My dad's degree is in electronics - He's an Electrical Engineer - He uses it every day. So I have a pretty good teacher ! Thanks Again !
Nov 21, 2011. 10:38 AMUATradition says:
Thanks a lot ! Another thing is the plexi glass - There were two two types at the store - The regular and the one that is supposed to hold up in outdoor conditions. I bought them both thinking the outdoor version would be better because it was just a tad bit thicker, but NOO - The regular worked far better to "hold" the near U.V. light.
Nov 25, 2011. 7:58 AMdimovi says:
Doesn't the outdoor stuff have a UV block?
Maybe that's why it is not as good - by design.
Nov 27, 2011. 12:33 PMUATradition says:
I didn't even think of that. HA ! I guess sometimes the most obvious things are the easiest to miss ! That has gotta be why it sucked. Good thinking !
Nov 15, 2011. 11:42 AMUATradition says:
Thanks for responding ! I didn't think I'd get an answer ! I researched a bit more and found out ... Another question I've got is why not this : (5.2v-3.3v)/.03mA to find resistors needed ? 5.2v = source, 3.3v = led volt. and you know the mA. I have not been able to find an answer to this ! (Just by me researching on Google) Is there an actual explanation for why you didn't find resistance this way or is it cause this is a bit more simple and user friendly way of doing it ?
Nov 15, 2011. 2:48 PMUATradition says:
I guess also if I would have really paid good attention you answered this question in your reply to my question yesterday !! Ha ! Thanks Again !
Nov 15, 2011. 2:46 PMUATradition says:
That's what I came up with using the method you gave - 173. I have read and read and re-read the Ohm's Law wiki page - HA ! I think that's what I'm going to do is go pick up a book because this is all SOOOO interesting !! And THANKS for the explanation and your time !! I really appreciate it.
Nov 15, 2011. 12:05 AMUATradition says:
(removed by author or community request)
Nov 15, 2011. 11:44 AMUATradition says:
Also - This is a neat idea - I'm sure you've been told ! I see you've been told ! Even 3 years later ! I'm making one of these for my little sister for her b'day coming up - So thanks for the idea !!
Oct 12, 2011. 6:09 AMvasudha1 says:
this ones really coooool !!!!!!!
Nov 4, 2010. 3:28 PMCharlie13 says:
it'd be cool to adapt this to a message board format for a college dorm or something. put this thing up in your room and have the girlfriends leave you secret messages
Mar 12, 2010. 2:46 PMfrdmrckr says:
just out of curiosity, how does this perform in light?
Feb 4, 2010. 1:03 PMFranco1 says:
I've often wondered how to do something like this.  This is excellent work, very impressed 'young fellow me lad'
Aug 13, 2008. 4:59 AMslayer_x911 says:
very neat, btw, highlighters ink also glows under blue leds light, u may try orange highlighters, looks cool also :)
Aug 13, 2008. 1:59 PMslayer_x911 says:
yea, i also think its brand-specific, cuz i have an orange highlighter, the brand is ( sanford liquid accent) , it glows strongly under both UV & blue leds
Aug 13, 2008. 5:07 PMslayer_x911 says:
it glows slightly greenish orange, try mixing your orange ones' ink with the yellow ones and see what happens, also try different combinations with the yellow but make the yellow ink more since it's the most glowing and find out the best colour for a night light or the one you like the most, keep me informed ;)
Feb 2, 2010. 4:38 PMevanwehrer says:
 Try liquid highlighters
Sep 7, 2009. 7:30 AMhunter9t9 says:
can you tell me how to make uv ink at home
Aug 2, 2009. 2:21 AMTobita says:
Loctite FTW! not much holds metal warhammer models like it xD
Jul 21, 2009. 4:41 PMbusyb0y says:
I bought a pack of 2 UV LEDs at Radioshack, and it says that the FW power supply was from 3.2v to 3.8v. So, do I need any resistors?
Jul 21, 2009. 4:47 PMbusyb0y says:
Oops I forgot a vital piece of info! I wanted to power it with 2 "1.5v AA" batteries.
May 1, 2009. 11:49 AMAndySavage says:
Can you wipe off the marks from the highlighter, or is it permanent? It would be really nice if one could wipe it off and re-write on the board, just like a dry erase board..
Apr 12, 2009. 3:54 PMmickey11736 says:
if it works out i will get a photo of it for ya. i have been for years using dry erase markers on the windows to write directions down etc...
Apr 12, 2009. 12:10 AMmickey11736 says:
wondering if you have found any other markers that will work on this? I drive truck, we use dry erase markers on the windshield all the time for directions. At night they are hard to read. if we could find some that could glow under U.V. light it would not be hard to make this as a 12V. instead of house hold current.
Apr 8, 2009. 7:39 PMeyebot117 says:
Your highlighters would probably all glow if you used a flourescent black light instead of LEDs. Just a quick thought.
Apr 8, 2009. 7:38 PMeyebot117 says:
Now that I saw this, I want to make a clear whiteboard and use my flourescent black light on it. That way I could write all my evil plans on it at night!
Jul 22, 2008. 7:30 PMOedipwns says:
How much did the plexiglas cost you? At my local Home Depot, the thickest piece (close to what you have, by looks) is over $25. Any suggestions?
Feb 20, 2009. 2:51 AMSeifpic says:
For me, the guy gave it to me for free!
1-40 of 57next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
84
Author:biochemtronics
After a career in industrial electronics I went back to college and now do DNA research.
