I cant think of anyone that wouldn't enjoy a  hand painted umbrella! My instructable displays easy and fun steps to create your own umbrella to keep or to give as a gift!
Step 1: Supplies
an umbrella blank
acrylic paint
Chromacryl textile medium
sharpie markers, and/or sakura markers (waterproof)
brushes, hair and bristle
masking tape
Step 2: Design
With a pencil draw your image on the umbrella. Sometimes holding a piece of cardboard  behind the panel  helps support the fabric.
Step 3: Tracing
Trace all pencil images with waterproof marker, again holding the cardboard behind makes it easier to support the surface.
Step 4: Painting
Mix Chromacryl with the acrylic paint according to directions. I wanted transparency, therefore, I added extra medium to my acrylic. Apply a very small amount of paint using a bristol brush and scrub the paint into the fabric.
Step 5: Heat Setting
Use the hottest temperature possible for the fabric type to heat set the paint.
Step 6: Other Designs
The flower umbrella was painted on a tan umbrella with the transparent paint application.
The lizards and the houses were painted with the acrylic and textile medium mixed according to the directions.
  • Paper Contest 2018
    Paper Contest 2018
  • Trash to Treasure
    Trash to Treasure
  • Science of Cooking
    Science of Cooking
When you heat set, do you iron the non-painted side? Or the painted side?
Hi! I tried acrylic on nylon once and it has a problem of "sticking" when the umbrella is closed/wrapped. It's fine, i just worry I would open it too fast one day and rip the fabric or lift the paint. I didn't heat set. Would this solve it? Does it need a fixative? If so what kind? Thank you.
Hi Dyscea,
I have never used just acrylic paint on umbrellas. I always add Chromacryl textile medium to the paint. If I use fabric paint I heat set. But you should always leave the umbrella open to dry.
When I've used the acrylic paint with textile medium added i have left umbrellas closed for over a year and they open fine.
Hope this helps
I'm also attempting to add art to a nylon fabric umbrella. My question "Is the heat source applied to the fabric or close to help in the drying process?
No It is meant to help "Heat set" the paint into the fabric. Don't set the iron too hot.
Good Luck and Have fun
I'm worried that after time with opening and closing the umbrella the paint will start to chip, have you had any problems with this?
No...mine is fine, always let the umbrella dry in the open position.
Do you know where I can purchase these types of umbrellas? So far all I can find are the nylon ones...
I'm sorry to say I don't know...I used to be able to get them for a reasonable price but over the years they aren't distributed any more and you can only g them retail and they can be as much as $40-$60. Thats why I switched to the nylon umbrellas.
