3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
UPS Hack! Hide your..
Hide your important computer files in plain sight!
You kids, your wife, not even that pesky burglar will know it's there.
This instructable will show you how to turn the dead UPS Power Backup into a discreet external hard drive for under $20.00!
Watch the video for the overview:
Step 1Supplies
The supplies you'll need:
- Broken UPS with USB port
The one I used had a standard type B plug, but you can also use the type that have an RJ45 instead.
It doesn't have to be broken, but there usually isn't enough room inside for the battery plus the hard drive and USB converter PCB.
- Used laptop hard drive
Don't use one that is too large, as the single USB port may not be able to supply enough power.
I found a 20GB drive on Craig's list for about $10
- USB 2.0 Enclosure for 2.5" Laptop Hard Drive
I found one made by MSI at Micro Center for $9.99.
- Soldering Iron, OHM meter, screw driver, wire cutters, etc...
75 comments
1-40 of 75next »
Apr 16, 2011. 1:50 AMdog digger says:
Be careful. The transformer could mess up the hard drive
Nov 1, 2010. 5:56 AMrunningduo says:
Now i know where to look in someones house for there hard drive
Jul 1, 2010. 7:07 PMChrisInVT says:
I don't think having a hard drive in the same enclosure as a 120v transformer, wiring and electronics is a good idea. Very creative though.
Aug 14, 2008. 7:09 PMsrilyk says:
The only problem I'd have is that "pesky theves" tend to steal the UPS as well :P It would work better to put something like... inside your wall.
Aug 18, 2008. 4:05 PMcompudude86 says:
"The only problem I'd have is that "pesky theves" tend to steal the UPS as well :P It would work better to put something like... inside your wall." you know, thats not a bad idea!! rig up something like a usb-rj11 deal and wire a usb drive into the back of a phone jack plate, or something similar, nobody would be the wiser except the phone repairman when your wife-girlfriend-mistress-significant other calls about the phone jack not working ;)
Jun 28, 2010. 11:00 AMdrresearch says:
There is an instructable that hides a usb drive in a wall phone jack box. http://www.instructables.com/id/Hidden-USB-Storage/
Apr 13, 2009. 7:00 PMPhvxoui says:
Actually theres a instructable on here somewhere that shows how you can use a Ethernet port/cable with USB or a Phone like as a USB very simple i think ab about to cut a hole in my wall and Install a Ethernet port! lol Sweet!!! !Peace from teh Middle East!
Apr 14, 2009. 3:35 AMsrilyk says:
Yeah, that's because USB == 4 wires, Ethernet == 8 wires, phone == 4 wires. I don't know about Ethernet, but phone pushes 9v I think. Maybe 12 - I can't remember and can't be bothered to look it up so early in the morning.
YEah, it would be rather simple!
Aug 18, 2008. 5:13 PMsrilyk says:
Just get one of those two port/two line phone jacks, or the network/phone jacks. Actually it shouldn't be too hard afaik the pinout on a USB is four wires, and some phone jacks have the four wires (the cheaper ones just have two).
Apr 13, 2009. 7:07 PMPhvxoui says:
you knwow hat would be good make it with a Phone cable and the end that goes in the comp (usb) leave that as the phone jack and you can get those cheap phone jack things from !$ store add a USB cable to that and you know use that as a converter... so only you will have access to it if you know hat i mean i know i didnt explain it in a very good way hmmmm this calls for a instructable!!!! lol maybe my first?.. gotta get permission to make a big hole in the wall LOL maybe just put a random phone on top of your comp and hide the HDD in that no is gonan steal a crappy phone
Sep 28, 2008. 7:58 AMkenn123 says:
Been thinking of similar thing.. Hidden USB HD are easily accomplished these days with a Solid state drive (heating problems...i think not) ...rough idea... Place SSD inside a small container attached to standard electrical faceplate, you can get a USB to SATA cable online these days for less than $10US
Apr 16, 2012. 3:56 PMsnowluck2345 says:
ssd drives are hotter than normal drives in many situations...
Oct 6, 2008. 5:25 PMshmuki says:
Oct 19, 2008. 5:41 AMkenn123 says:
I like it
Jun 26, 2010. 9:45 AMh3x_your_nightmare says:
nice idea...but it's kind of time wasting...you can do this much easy by putting a little USB hub after that built-in UPS's USB B and then connect the hard drive to that usb hub ;)...i don't know if you get the picture... sorry for my bad language ;) i'm from romania ;) have a good time ;)
Aug 18, 2008. 10:40 PMilldoyourdrugs says:
Cool Stuff guy. But wouldnt people be curious why you have a dead UPS on the floor by the computer lol. Other wise pretty clever
Jun 23, 2010. 2:44 PMdawsonj says:
yeah, it would almost make someone want to do your drugs
Jun 23, 2010. 2:41 PMdawsonj says:
very imporntant data
Jan 3, 2010. 12:56 AMberekleonard says:
Great idea. Albeit, I think like a thief and, in the midst of moving around computer things to unhook cables, I would notice a UPS that was 10-20lbs too light and that would tip me off.  I would add some weight to offset the missing battery.
Check out this instructable too http://www.instructables.com/id/Hidden_USB_Storage/
Oct 5, 2009. 6:30 PMWesley666 says:
Also the transformer (not sure about yours) but mine can be plugged into the wall and it puts out about 30 amps. I am trying to make an automated solder fed solderng iron, so sort of like a mini MIG welder. Not sure if it will work, I know the soldering parts work but I wonder if it would fry components.
Oct 5, 2009. 6:25 PMWesley666 says:
When you said, "your wife won't know" I thought to myself, this guys using this to store his massive porn collection probably.
Sep 21, 2009. 10:18 AM17hmr243 says:
couldn't u place micro sd in tiny zip bag u us guys call them dime bags ? and hide it layer of a zipo that works then it mite be stolen but who strip searches a zipo except me:)
Aug 26, 2009. 11:16 PMalbylovesscience says:
lol thats a good thing to do with a external drive fill it with pics of the great vanessa hudgens
Aug 10, 2009. 12:25 PMkdude63 says:
Great! Now I have a secret place for all my por... erm, secret files.
May 11, 2009. 4:53 PMKwitmeh3 says:
heh hide your po inportantpictures
Feb 3, 2009. 6:17 AMDIYDragon says:
That's be pretty cool to install something like that in the wall behind your computer.. mostly just because it'd be out of the way, and not because of needing to hide it! : D
Jan 10, 2009. 10:06 AMlucek says:
what would be cool is if you used a hidden wireless usb hub. . . . I just thought of the absolute best hiding spot. get an old crt monitor, gut it. install a usb monitor at the front (use bondo to make it look right, and bingo you have a 3 to 4 sq ft hiding space that no one in there right mind would steal.
Oct 14, 2008. 5:23 AMPeaceRabit says:
smart perv.
Sep 27, 2007. 3:01 AMfrosty1433 says:
"...what this hack is good for? imagine if you will, you've downloaded some po... important pictures..." ROFL!!!
May 25, 2008. 7:01 AMgrundisimo says:
perv!!!!!!!!!!!!!!!!!!!!!!
Oct 13, 2008. 10:34 AMplaneglory says:
whats so perv?
Oct 13, 2008. 6:30 PMgrundisimo says:
You don't understand what he meant?
Oct 11, 2008. 8:01 AMdavidprosser says:
Yeah I agree with a few people here - that if you were burgaled then they would probably take a UPS over a USB drive. The value these days is like $10 for a 4GB USB key, but a UPS is like $50 worth. Also, if the UPS did work, you could just unsolder the wires behind the USB socket inside, wire in a cheap USB Hub from ebay, and plug in your USB Drive AND wire the UPS. Voila!
Sep 21, 2007. 3:37 PMcorky842 says:
That's pretty cool. Instead of a hard drive, how about putting a USB flash drive in there? It wouldn't require an adapter, and there would probably be enough room to leave the UPS functional.
Oct 9, 2008. 2:59 PM=SMART= says:
Youve downloaded some por....important pictures... Hahahaha Nice ible 5*
Jun 1, 2008. 12:41 AMDerin says:
mine lights the fault led when i remove the battery
Aug 19, 2008. 1:59 AMthermoelectric says:
CUT THE WIRE!!!
Aug 19, 2008. 3:08 AMDerin says:
NEVAH!!!!!!!!!!!!!!!!!!!!!!
im gonna revive the battery at least
1-40 of 75next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
96
Author:NK5
