USA Arduino Interrupt LED Brightness
Introduction: USA Arduino Interrupt LED Brightness
In this project, we will be creating a Red, White, and Blue LED display with a potentiometer and a push button. Sounds easy, but also we will be using interrupts for this. So when the push button is pressed, the value from the potentiometer will set the brightness of the LEDs. The materials needed include:
-Arduino Uno R3
-male to male wires
-three LEDs (red, white, blue)
-push button
-220ohm resistor
Step 1: Power and Ground
First, connect the ground and 5v power to the breadboard.
Step 2: Connecting LEDs
Place all three LEDs on the breadboard. Connect the cathode to the ground for each one. Connect a 220 ohm resistor to the anode and then connect that to the arduino, pins 9-11.
Step 3: Push Button
For the push button, make sure you connect it exactly in the picture. Power to power, 220ohm resistor to ground, and then opposite end to pin 3. This will be used as the interrupt.
Step 4: Potentiometer
Just like the push button, connect the potentiometer just like the picture shows. This will serve the purpose for adjusting the brightness.
Step 5: Possible Errors
Make sure the pins are connected like the code and pictures show, and that they match. Also, make sure the anode and cathode are connected accordingly.
Step 6: Code
const byte ledBlue = 11; //sets LED blue at pin 11
const byte ledRed = 10; //sets LED red at pin 10
const byte ledWhite = 9; //sets LED white to pin 9
const byte interruptPin = 3; //the push button as the interrupt
const byte potPin = 1; //potentiometer is pin A1
volatile int bright; //LEDbrightness
void setup() {
pinMode(ledBlue, OUTPUT); //blue LED as OUTPUT
pinMode(ledRed, OUTPUT); //red LED as OUTPUT
pinMode(ledWhite, OUTPUT); //white LED as OUTPUT
pinMode(interruptPin, INPUT_PULLUP); //button pin as INPUT_PULLUP
pinMode(potPin, INPUT); //potentiometer pin as INPUT
//sets up the interrupt with input pin and brightness to RISING
attachInterrupt(digitalPinToInterrupt(interruptPin), light, RISING);
}//end setup
void loop() {
analogWrite(ledBlue, bright); //Sets the blue LED to the set level of brightness
analogWrite(ledRed, bright); //Sets the red LED to the set level of brightness
analogWrite(ledWhite, bright); //Sets the white LED to the set level of brightness
}//end loop
void light() {
bright = analogRead(potPin); //Reads in value from potentiometer
bright = map(bright, 0, 1023, 0, 255); //Maps values for LED brightness
}//end brighter
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    That's a neat setup :) Do you have any photos of the finished project?
