What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
can anione of u, help me out in designing this setup on basis of technical datas like( container volume, fan power,ice qty., temp. difference etc... ) required for 1 person nd for 15 persons ?
nevermind.. i used whatever worked haha. i made one! sadly, the fan is so weak.. i can feel it drawing cold air out, but its really weak. is there... an easy way to... say, use two USB outlets to combine 10 volts to power the fan more? I made mine out of this big Tin box that a bottle of southern comfort came in.. its really cool. looks nice and its really tall! I love the idea.
heres the pics of the version i made. Needs more juice in the fan area though. I used a plastic like CD case, it was bendy plastic to make holes in to hold the ice. It worked fine, drained without leaking. Cool instructable!
Ok, do as I did. I amped it up a little. I don't have pics now, but I will later.
Essentially, have one fan running air intake, and one to blow the air at you. Intake at the top, ice at the bottom, fan blowing air aimed at your face.
It's that simple, and all you have to do is rig it up to a single usb cord.
-=ACHTUNG!=- Note to readers: Do not OVERFILL your container with ice. If you do this, after the ice melts, the water will flow out through the holes you drilled.
I have not made one yet, but how do I find a container that fits a CD with holes in it. What size do I need? Also how much speed do I need for the fan to put out enough cold air and what size fan would you recommend. Thanks for showing me this project thanks, now I can probably build something better that will keep my netbook much cooler one day.
Recomiendo usar un motor de mayor potenciay debajo de la lata de matal colocar algo para que no sobresalga el agua accidentalmente. Un trabajo estupendo! =)
I have not tried this yet, but like the design. Has anyone tried it yet with crushed dry ice? I know too much of it will cause a lot of CO2 to go into the air, but something this small of scale it might work pretty well. Only reason I mention it is it would eliminate the water drip factor.
Air conditioning, just in time for November. :-) I really like the clever use of everyday objects to make that thing. Mounting the fan to a plastic lid is something I would never have thought of. Nice job.
Heres my version of ot, but its completely usb anymore, i made it a hybrid, i have a usb cord and a cord thatll plug into the wall that gives it a little more juice than the usb. i dont have them plugged in at the same time, that would most likely short out my whole computer haha.
in a usb wire there are four wires. red, black, green, and white. The red and black are 5v and ground. The green and white are for data transfer. In this project you just need the red and black. Also on the fan there is usually a yellow wire but ignore it. Just connect red to red and black to black and you should be in buisness.
Cool idea and neat concept! This is governed by the same principle as a swamp cooler. One suggestion is to make a hood or rig something up to direct the flow of air toward you so that the effect will be felt in a much more noticeable way! Nice!
If you're doing that, use Ice packs (Such as Nordic Ice) or frozen water/gatorade bottles.
And use some fans to draw air in.
Make sure that the holes are NOT at the bottom of the tin. If you do this, after the ice melts, the water will flow out of the holes.
thanks for the idea
Note to readers:
Nice design, by the way.
