USB Batman Spotlight
Step 12Make the spotlight lens
Place a sheet of clear plastic (OHP slide or old bit of packaging) over the top of the spotlight and mark a circle (water based ink) just inside the inner wall of the lamp. Add three tags to the circle and then cut it out. Then wash off the marker pen, and then dry. When dry, stick a small square of double sided masking tape to each tag, but leave the backing on for now.
Measure the inner circumference of the lamp and make a foil strip that will fit neatly inside the lamp without sticking up proud from the top.
On a similar piece of foil mark up and then cut out the Batman logo. The logo must fit the area of the lens. Put a strip of double sided sticky tape on the back of the foil before you cut it out.
Get images to copy from off the web, or go to thedadcando batman project where there is a downloadable template of the bat logo (and the mounting yoke, you will need in a minute).
Cut out the bat logo and using double sided tape stick it to the lens in the center. Fold the tags down.
Insert the foil strip into the lamp and then insert the lens tags and push the lens down so it is level with the top. The best way to down this is to peel off only one of the tags double sided, poke this tag in and stick it firmly and then push the other tags in and pull off the double sided backing with tweezers or the corner of your craft knife once the tags are in place.
Make sure that the tags go down in between the foil and the lamp wall, so they are hidden when it is assembled.
3 comments
Nov 20, 2010. 1:28 PMboudreau-inventor2 says:
Do I really have to join to get the batman template, and mounting yoke????
Feb 20, 2011. 11:32 PMFlying_MashedPotatoes says:
imma use this one: http://www.photoshopstar.com/wp-content/uploads/2008/06/batman-logo.jpg
Dec 15, 2010. 5:12 PMJerminator says:
Joining has no cost. You just need to have an email, and its very easy!
Dec 19, 2010. 10:35 AMV1LL33 says:
Actually it does.. I was going to register at that dadcando site thingy, to get the template. After the registration they asked for me to choose which payment method, similar to this sites' one. Now, I have to ask my sister to draw it.. Would be simplier to just print it for free..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
312
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
