3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Bike Generator
Step 5Final Results
Final Results
Before I did the final assembly of everything I tested the performance of the new stepper motor, diodes and switching regulator.  I used a dead 5V 1000maH battery as a load and measured the current and voltage input and output of the regulator.  I used the drill press again to turn the generator at its 5 different speeds. The results are listed below.
RPM                           620     1100      1720     2340     3100
Vin (volt)                    5.81      6.61       7.15      7.43       7.67
Ain                              0.15      0.26       0.34      0.38      0.40
Vout                            3.70      4.21       4.55      4.78      5.05
Aout (Amp)                0.15      0.28       0.37      0.42      0.44
Input Power (W)       0.87      1.72       2.43      2.82     3.07
Output Power (W)    0.56      1.18       1.68      2.01     2.22
Efficiency                   64%       69%      69%      71%     72%
As you can see the regulator is right at 70% efficient between 1100 and 3100 rpm.  Also it generated enough power for the USB ports even at 620 rpm.  I also increased the size of the wheel mounted to the generator to slow it down compared to the old BikeGen stepper motor.
All of the work comes to this final point. The USB Bike Generator can power two USB ports as you ride your bike, to charge your electronics.  The electronics of the system are 70% efficient above 12 mph bike speed and can generate adequate power at 7 mph.  I have tested a rechargeable battery, handheld GPS and an Eton radio with the USB Bike Generator and they all work.  I have also tested a Ipod touch 3gen and have found its is possible to charge but because of the variability of the power source and the pickyness of the Ipod its not very reliable.
I welcome all comments, questions, and suggestions. Thanks
5 comments
Jul 8, 2010. 1:00 PMtexasclodhopper says:
(removed by author or community request)
Mar 21, 2011. 5:55 AMroland985 says:
When I go for rides, I spend roughly 30 minutes each way, 1 hour. Enough to give my smartphone a full battery. I have bought a commercial version of this.
But yes, storage is desirable, make your version with storage.
Aug 17, 2010. 12:52 PMpteranosaur says:
Clod Hopper-More research,you need MORE RESEARCH...lol
Jul 18, 2010. 1:28 PMwatermelonhead says:
Actually, in the second rebuild of this project, he did just that... instead of directly powering the headlights, it recharged its batteries. He also says that this is not to power, but "The USB Bike Generator can power two USB ports as you ride your bike, to charge your electronics."
Jul 6, 2010. 4:02 PMtraeblain says:
Last question...but why did you choose to abandon the intermediate battery approach you used on your previous generation? I would think the battery could take the flaky charge gracefully, then you'd have clean output power to your devices and would correct for issue with the ipod charging reliability?
Dec 2, 2010. 1:15 PMbrickbreaker says:
Well obviously more research is required before you start building a battery addon for this build but I would like to point out (if its not too obvious) that modern devices with lithium batteries have a set up that prevents over charging. Maybe hacking an old device to be your bike-battery would be easier than building your own circuit? Just a thought.
Jul 7, 2010. 11:34 AMlahtib says:
Have you considered the use of a capacitor? It might provide some stability while removing the concerns of a battery charge?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:dbc1218
I enjoy building things more than actually using them.
