3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
USB Biofeedback Game Controller
Step 3Preparing the bottom of the project enclosure
Next we'll prepare the Arduino project enclosure.
First, trim down the two middle supports on the bottom of the enclosure. Leave enough height so that they will still go through your Arduino mounting holes but not go past the Arduino headers. (Pic 1)
Next, place one of the muscle sensors in the bottom left of the enclosure by sliding the bottom left support through the muscle sensor's mounting hole (the one near the female headers). Straighten the sensor by rotating it around the support such that its sides are parallel with the enclosures. Gently and such that you don't jostle the sensor board, slide your plastic insert onto the enclosure and hold it above the sensor. Now, look down the rectangular cutout on your insert and verify the three male headers of your sensor are directly below. If not, remove the insert, adjust the sensor position and repeat until it is in position. Once it is in position, mark the location of the muscle sensor's second mounting pin, remove the sensor, and drill the hole.
Note: If you don't get the hole in exactly the right position, it's OK you can just widen the cutout more to compensate.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:Gundanium(Advancer Technologies)
Brian Kaminski Owner - Advancer Technologies Brian graduated from North Carolina State University with a BS in Biomedical Engineering with a concentration in Biomechanics in May, 2006. While at North...
more »
