Introduction: USB Computer Fan
Picture of USB Computer Fan
This is a way to repurpose old computer fans as well as USB cables. I'm using mine to cool down an audio reciever that has a tendency to overheat
Step 1: Stripping the USB Cable
First you take wire cutters or scissors and cut off the end of the USB. Try to cut it as far towards the end this way you have more wire to work with. You then take wire crimpers (or scissors if you are skilled enough) and remove the outside covering of the wire.
Step 2: Stripping Individual Wires
Picture of Stripping Individual Wires
Inside the USB cable you will see a red wire and a black one. There will probably be others like white or green, but those dont matter so you can cut them off. Some USB have a white wire as the negative and gray as positive, but those are less common; most have red positive and black negative. You want to strip the coverings of the positive and negative wires just like before.
Step 3: Stripping the Fan Wires
Picture of Stripping the Fan Wires
The fan will probably have some sort of plastic at the end used to connect to the computer, but that is no longer necessary so you can cut it off as well as any wire that isn't red or black. We then strip the wires again.
Step 4: Connecting the Wires
Picture of Connecting the Wires
Next you take the red fan wire and twist it onto itself so the metal wire spirals and straightens into one wire. Do that with the black fan wire and both the USB wires. After all the wires are twisted on themselves neatly you take the black fan wire and twist it with the black USB wire. Do the same with the red wires. Wrap the red and black wires in electrical tape SEPERATELY so the red doesnt touch the black and short out. You can do this with multiple fans onto one USB like i have.
noobguy57 (author)2017-10-26
I made this! But I have one question. I am using an old computer fan for intake and exhaust via USB for a project I am making with a lot of electronic parts that could get hot. The fan doesn't spin at full speed. Is there a way to fix this? I am curious.
genterara (author)2014-10-22
But arent' most fans 12v and USBs 5v?
A lot of fans can undervolt to 5v. Which is also how some built in fan speed controllers in some computer cases, for example, the fractal define series, control fan speed, by turning down the voltage and decreasing RPM.
Thank you for a good point. I connected my computer fan with Arduino +5V and GND and it worked. Fan rotated.
henrytheunicorn (author)2015-06-22
Wait a minute, if the USB 5v is split among the 2 fans, since they're in parallel i think, don't both fans get 2.5V?
I'm confused :|, I thought 5v was bare minimum per fan
About This Instructable
2,730views
32favorites
License:
More by mcoyle4:USB Computer Fan
Add instructable to:
