Step 1: What you need
motor, (port USB = max. 2,5W !) 2 Cd, USB cable, papier or plastic tube
Step 2: Windmill
Cut and form CD or DVD
Step 3: Cable
Prepare USB cable, leav: red and black
Step 4: Folding
Step 5: Finish
1-40 of 67Next »
Schmidty16 says: Jul 19, 2012. 12:24 PM
im making a fan like urs but im useing some plastic from a beading box i found at my houst it is approximly 2inches and im useing a moter from a portable cd player its a little small and loud bit it works
mingus15 says: Apr 21, 2011. 1:11 AM
hello,
can some help me?!
how to make the cd past in that angle?
did you remove them and atacht them again with glue?
bb
uberdum05 in reply to mingus15Aug 13, 2011. 2:24 AM
I once saw a method where you cut the CD as shown above and then you can heat the part where the cuts meet and then just gently twist the blades :)
adrian09 says: May 8, 2011. 11:05 PM
are u german?
tobyscool says: Apr 16, 2011. 12:30 AM
nice fan i am definitely going to make one while its summer here :D
S5114 says: Jul 15, 2010. 12:36 PM
What's the orange thing in the 2nd pic.?
jackh94 in reply to S5114Jan 18, 2011. 12:07 AM
it's just a connector, wires get put in both sides and the screws lock them in place
smart_thingup says: Feb 21, 2010. 10:34 PM
 i've done make this cool fan,.. thank you,...
johnnyboi says: Mar 1, 2008. 4:47 PM
where would i get the small motor?? from a old tape radio? im still not sure how you do the wiring and if you really need to solder it... im stll a beginner
hock3ydud3 in reply to johnnyboiMar 1, 2008. 5:13 PM
radioshack has a bunch of them for $3 to $5 and something like a tape player or old hairdryer or something like that would work
=SMART= in reply to hock3ydud3Apr 17, 2008. 5:23 PM
god dammit i wish we had radio shack in the uk
linuxthefish in reply to =SMART=Nov 15, 2009. 11:44 AM
i wish we had one too! :)
lifelong-newbie in reply to =SMART=Apr 18, 2008. 2:59 PM
Me too. Next best thing is Maplin for high street components, but they are expensive and no where near as common as Radioshack. My nearest is brighton, 13 miles away. a 20 min train journey to buy a resistor, not gunna happen.
=SMART= in reply to lifelong-newbieApr 18, 2008. 4:31 PM
lol yea maplins is a bloody rip-off, i just get what i need from my DT department at lunch break when there's no-one around, not a very big choice though, switches, leds, and motors nothing special.
weretater says: May 11, 2008. 5:00 PM
Is there any easier way to cut the cd? because every time i tried, it kept fracturing, making that blade worthless.
555mst555 in reply to weretaterJul 12, 2009. 1:55 AM
u can use a scicors....just use a sharp one....blunt ones make the CD crack
bassmasta1010 in reply to weretaterApr 20, 2009. 1:20 PM
get someone to blow on it with a WARM NOT HOT hair dryer and cut it with scissors or watevr youve got....
Bartboy in reply to weretaterJun 29, 2008. 8:12 AM
Exacto knife
power in reply to weretaterMay 17, 2008. 1:57 AM
by using cutter,slowly cut it.the best way
Pulha says: Jan 3, 2009. 12:39 PM
erm... i did all exactly as it says in the guide but when i put my fan in usb, it works but my mouse turns off -.-
CalcProgrammer1 says: Aug 10, 2008. 10:38 AM
How are you supposed to bend the blades? I cut 8 sections but they won't stay angled after I bend them. Oh, and if you do this with CD-R's, you'll get flakes of shiny reflective paint everywhere.
cowscankill in reply to CalcProgrammer1Dec 22, 2008. 11:00 AM
Use the candle to melt the blades a little at the base
imnotniko says: Nov 5, 2007. 12:43 AM
thats really kool. where can i get a that little motor from though?
imshanedulong in reply to imnotnikoOct 27, 2008. 6:48 AM
A dollar store car.
ticky2143 in reply to imnotnikoOct 24, 2008. 9:44 AM
take apart an old r/c car
tubbychick3n in reply to imnotnikoAug 31, 2008. 2:46 AM
also if you have an old cd player, if you taek it apart, you can get a motor out of it that has a spot that lets the cd snap right in. it's the part that you actually put the cd onto.
bassmasta1010 in reply to tubbychick3nApr 20, 2009. 1:17 PM
oh yeh i broke open a old cd player that sukked and i found 2 or 3 motors, wire, switches, capcitors, and a lot of stuff
tubbychick3n in reply to bassmasta1010Apr 22, 2009. 4:08 PM
Yep. They're actually quite useful for electronics of all levels. The one i opened even had 2 audio connectors that i plan to use for an amplifier.
shammallamaman in reply to imnotnikoAug 20, 2008. 5:36 PM
Radio Shaq, they sell them relatively cheaply
y0urm0msname in reply to imnotnikoNov 17, 2007. 10:41 AM
you could always get it from an old optical drive http://www.instructables.com/id/USB-Cooling-Fan-from-a-broken-drive/
n0ukf in reply to y0urm0msnameMar 7, 2008. 1:04 PM
I just sttripped down a CDRW to see what usable parts I could find in it. For this project you'd likely have to use the tray transport motor, since both the head and disc drivers were stepper motors and need a specific pulse stream on 2or more sets of windings. Though a cheap stereo system (radio/tape/CD) I stripped a while ago had a regular DC motor for the disc instead of a stepper. You just have to see how they're connected (2 terminals are simple, just add DC).
killerjackalope in reply to n0ukfApr 3, 2008. 9:42 AM
It's only the CD writers will have a stepper, reader only just has to turn away so it's almost always DC motor...
Metaferia says: Aug 20, 2008. 4:05 PM
hi, what did you put in the cd hole? so you can glue it with the motor?
shammallamaman in reply to MetaferiaAug 20, 2008. 4:54 PM
It looks to me like a cork
Metaferia in reply to shammallamamanAug 20, 2008. 5:25 PM
ok, thanks, i will try it
shammallamaman in reply to MetaferiaAug 20, 2008. 5:34 PM
No Problem
shammallamaman says: Aug 20, 2008. 5:01 PM
Very nice, I like the way you think
jetsmiley123 says: Aug 12, 2008. 11:28 AM
i cut a little material out from in between each fan blade to give it some room to suck some air in and it prevented it from fracturing when bending it over the flame. here's a picture of what it looks like,
Nunavutnewsrules says: Jun 4, 2008. 10:39 AM
I think i will make one of these but i will add a wire cage to it. Yea i like my fingers and knowing me i would accidently put something important behind it and it would be destroyed.
Bartboy in reply to NunavutnewsrulesJun 29, 2008. 8:12 AM
If you have knex, that whould be VERY simple
1-40 of 67Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
